Everything posted by Royal Squire
NO BUS message on odometer
Guess I should stop complaining.
2010 T Steering Drag Link Adjusting Sleeve
IIRC the 98 & 99 have a different taper on the tie rod ends so won’t work on 00-02.
You know when you're old...
Mine was a 1941 Chevy pickup. Paid $25. Owner didn’t know if it would run, it did. I was 13 years old. Drove it around the farm for a couple years then sold to my brother. At the same time I bought a 51 pickup for $50. Owner said it would run and it did but coolant ran out the side of the block. My son has it now.
W-T ground mod
You can tin them yourself with solder if you want them tinned
Window Chatter
Try a little powdered graphite
'00 24v Cummins - What tuner to get?
Dynamic sells transmissions and parts as well.
Not sure. Want them to repair it if needed. If it doesn’t need repair hopefully they won’t charge me for repair.
Sending PCM in to ACS and thought it would be same cost as ECM. Not so. $450!!
I earned a Doofus award!
A friend used to call my brother “Sparky” for that very reason.
Thanks Mike. I will get it sent off tomorrow.
@Mopar1973Man, @Haggar, @IBMobile, @Me78569 I got my ecm back from ACS for the second time but am afraid to plug it in. Went through P1698 diagnostics as shown on the site here and all checked out till I get to #6. It says if resistance between terminal 31 and ground is less than 10 ohms, replace PCM. Did a similar test on ECM connector, terminal 30 testing P1694 and it says to replace ECM, which is fresh rebuild so should be ok there. Do you fellas have any other suggestions before I send my PCM in for testing/repair? Really appreciate any help you can give me. Thank you
DYI- what do you do yourself vs have done?
He has an 04 model. Is that the same?
Creaking squeaking door panels
Look at what they used on dash bezel
can i use v10 tank on 12v?
12 valve has camshaft-driven lift pump on side of block
Injector Connector Tube
Almost looks like it’s been on fire
Homemade bumper
@Gregturley I usually remove ball mount when not towing as it makes a really good knee knocker
Qaudzilla woes
@Marcus2000monsterI believe you said it idles rough in warmup mode. If you have factory high idle enabled and try to use quad high idle it is my understanding they are unfriendly
Qaudzilla woes
@Marcus2000monsterwhile I have never had a Quadzilla and don’t know much about it there are folks here willing to help you. It has been my observation that you like to jump in to help others who have questions that come to this site. It seems that you are younger than many others here and I believe it would be a good thing for you to invest the time to learn how to tune and in the not-too-distant future you could be coaching others who have tuning questions. Just my $.02.
Need to ground my tool box.
It’s all about liability
LED lighting - Exterior lighting
Is it just me or is anyone else blinded by the new F-250/F350 factory headlights?
LED lighting - Interior lighting
Superbrite leds has a led flasher on their site. Sorry the link may be too hitech for me.
Machine shop
At demolition derby many years ago just after high school we used Copenhagen in radiator. Worked till distributor cap broke. Don’t know about long term.
Dead truck P0216
I believe it is recommended that you just barely crack that needle valve open.
No fuel pressure but Fass pump is working.
They may ask if you’re using a tuner. They asked me
2001 auto, Rattle near steering column
Rock solid ram is what aftermarket bushing is called I believe.
