Everything posted by Royal Squire
ECM gone. What about VP
I disconnected lift pump from ecm, hooked to 12 volts and drove 40 miles pulling a load and seemed fine. I didn’t want to take a chance on starving VP44 any more.
@Mopar1973Man Yes pump has a relay. Actually the in-tank pump had a relay. @dripleyI’m not sure about much except when I lost pressure, truck began running badly and as soon as pressure came back truck smoothed out completely.
Up yet?
Does that come with sound?
Wanted to use some of you fellas experience. My ecm quit powering lift pump so most likely will need to replace it. When I lost fuel pressure, engine began to sputter till fuel pressure returned and got a p0216. AC voltage is ok and code hasn’t returned since cleared. Do you think my VP is ok and code showed up because I lost fuel pressure or is injection pump gone too?
Oil Pressure and oil type
I would check with mechanical gauge pronto
Power Steering Pump
Pump can be easily rebuilt
'The Boost Bus'
Maybe use camouflage tape and no one would see it
Knocking brakes
Is he willing to send you another kit?
Knocking brakes
I would be talking to the seller especially if its not just you having this problem
Going to look at this tonight
Looking good.
AC not cold
You can also rent these tools if you don’t want to buy them right now.
AC Compressor “short cycling”
It seems my skin is paper thin these days
@dripley are the back of your hands and your arms all scratched up?
New from Tennessee
When my in-tank pump was installed the fuel line ran through a block that replaced factory pump so the fuel lines didn’t need to be modified.
Boost elbow and fooler
Monitor fuel pressure.
24V fuel filter fittings help
If you contact Vulcan Performance, an advertiser on this site, they can fix you up with whatever you need if you explain your intentions
New from Tennessee
Probably not!
Problems with dead pedal between 25mph and 45 mph
I too have a raptor pump and while not the best answer, it seems to work fine. My reasoning was that l believe gauges are important also and with limited funds that’s what I could afford at the time along with gauges.
Anyone rebuild their hydroboost unit?
If I remember correctly I believe @Haggar rebuilt a brake booster. Had a description and some photos. No idea how to find them.
Well the Order is in
Good news-right?
Is it gonna be electric?
Bumpers any advice
I believe somewhere on the site is photos and description of a member welding up his own bumper.
Rattlesnake Fire, Idaho - 2018
Some of it is due to storms that have lightning and no rain
Aftermarket injectors?
Could just buy a second!
I need help spending some money
While you’re in there you might consider changing tappet cover gasket
