Everything posted by Royal Squire
330IT Mom wagon project
Got rid of 2nd gen so needed something to replace it
Speedometer jumping
I believe some higher end code readers(snap on, DRBIII, etc) can read abs codes
Speedometer jumping
Could it be because you’re out of washer fluid?
Speedometer jumping
No WTS light
New NV 4500 with South Bend DD, full package with 1-3/8th input. ( 4th gear vibration on deceleration) trouble
Don’t think so as pilot bearing is on front side of clutch disc however someone else here likely knows better than I
Rear door hinge pins
Some body shops have a hinge pin assortment and you may be able to find something that would work.
Kelderman rear suspension question
How about a photo or two of suspension
My Love affair with BMW
Glad to see you got your fix. Good looking wagon
A little bit of what I do for work...
That is amazing
On board air
More photos please. Where did you mount 3 compressors?
Ugh, 47re service
Sorry to see this. That tranny fluid makes really good red dye!
Alignment specs??
Once your tires have started to wear they likely won’t get better
Case 1835B skid loader drive chain
Photos??
Transmission cooler line clips
Could a person make one with a 3-D printer?
No trailer running lights on 07 5.9, also truck is losing prime at under 1/2 a tank
I’m the last one who should comment on electrical problem but.....Might be ground. Hook battery cables between truck and trailer.
No bus, no cluster, truck does run though
When I had the “no bus” message my testing led to bad pcm, so sent it to ACS and tested good but they had a difficult time getting a good connection with it. So that seemed to be my problem. I cleaned connectors again and plugged and unplugged many times and everything worked. ACS suggested to not use dielectric grease. Hope this is helpful.
The crf450ish random question thread.
Can you just add a muffler or resonator to your 5” and save a few bucks?
Installing Isspro FP gauge in stock 01
About 30 years ago I went to work at a Napa store, before they used computers. First thing owner told me if I had spare time look through parts books to get familiar with them. Several times he told customers that a part wasn’t available and I showed him it was. Don’t know how they do that now days with computers.
One cup and one pot, to pee in that is!!
Remember, food doesn’t have to taste good it just has to keep you alive, but I would rather it was good!
Hey you guys I got to get rid of a skunk.....
They might if you guarantee them an income!
Hydralic Brake Booster , possible leak
There is a rebuild article here somewhere
Is that pot an air freshener??
Cellphone service at home
Did you have any cell service before adding the network extender?
Parking brake problem?
Would “starching” make the cables shorter??
Truck died second version
You can use the OBD 2 to check for codes. The DRB III is pretty pricey.
