Royal Squire
Everything posted by Royal Squire
  1. My dodge had agm batteries when I bought it. Because they are pricey I probably never would have purchased them since 2 are required, however, it sure is nice that the tops and terminals are always clean!
  2. If elk is tied to a tree you could just run up and cut off some steaks!
  3. My nerf bars are Lund I think. They were on truck when I bought it. I like them not only for making it easier to get in but I also stand up on them when getting out which saves sliding off the edge of the seat which will hopefully help save the seat foam/cover.
  4. Don’t use your hand for a hammer!! You’ll regret it when you get older
  5. I’m not the guy to give advice on posting photos but someone else will probably chime in eventually.
  6. Welcome. Sounds like a great project. Got any photos?
  7. Maybe $400 isn’t too bad for all that
  8. Is that both sides of all 6 wheels?
  9. I ordered a set of rv275 injectors from dap, and after I installed them, the truck barely ran. I called dap and they promptly sent me another set with a return label for the faulty set. I thought that was good service. Just my $.02
  10. The ranch my Dad worked at when I was growing up had KB2, KB5, KB6, and KB7 trucks. They were all gas powered. Check out those mirrors! The trucks we had only had a mirror on the driver side. Can’t see much out of those little round mirrors when trying to back up to a cattle loading chute.
  11. Good to hear your dad is getting better after such a long illness, sounds like time to move.
  12. I too use a funnel and often make a mess anyway
  13. I would talk to Eric @ Vulcan. My guess is he can help you relocate that pump with the proper wiring harness/relay, fuel line, pickup, etc.
  14. It separate of the bezel just like the later models
  15. You can probably find a video if do a search
  16. What’s the transmission out of?
  17. Absolutely others are interested. You should do a separate article. How many miles!!?
  18. Any idea why my scanner didn’t show any codes when I had it hooked up?
  19. How do the lights on the 2018 compare to previous years?
  20. I just had a belly hernia repaired and am pretty sore so may not be doing much for a while. I guess will have plenty of time to read.
  21. My son took truck to town and had trouble getting back. Scanner shows no codes. Key codes are: P0123 P1694 P1693 P1687
  22. Certainly don’t want to spend money unnecessarily
