Royal Squire
Everything posted by Royal Squire
  1. @KATOOMwhat is the “T”post you are referring to?
  2. Wouldn’t it work to put a toggle actuated solenoid between battery and relays. I’m kinda electrically challenged but was curious if this would work.
  3. If I’m not mistaken, if a transmission has a rear pump like a TH 400, it is possible to push start, though I’ve never done it. Maybe @Dynamic has some input on this.
  4. Didn’t mean to criticize, it just seems I’m so easily confused these days. You’re saying that a 24v is easily started by rolling down a hill and releasing the clutch? I’ve pushed or pull started a lot of vehicles, but never one of these. Thanks for sharing your wealth of knowledge.
  5. In my experience, “jump starting” usually refers to the process of starting by using jumper/booster cables between a fully charged battery and a discharged battery. Don’t believe that is what you’re referring to here, so was confused for a minute. Maybe another “regional” term.
  6. Might consider replacing tappet cover gasket while you are so close.
  7. Isn’t that creeper called a “bone”
  8. @Mopar1973Man Mike to do that quick reset do you turn the key on before disconnecting the batteries?
  9. @BobalosHow long does the 80 step take?
  10. Did you have all accessories turned off and engine warmed up before testing?
  11. @woodtruckerIf you’re adding a full 3 gallons I believe it will be a quart over full.
  12. You could loan him your truck till the new one comes in. Maybe he’d even give you a ride in the new truck
  13. @Me78569I know this is off topic, but how come you’re without a truck?
  14. If you call Vulcan they will help you figure out what you need.
  15. When I did mine I cut off the female quick connect and just shoved the hose over the male and clamped it. Wasn’t easy but I didn’t want to drop tank again.
  16. Had a neighbor that lost a joint in rear drive line on his bronco and drove for quite a while with just front shaft. Never went very far or very fast though
  17. You could just remove it
  18. @BBHD You could call that a small issue. Is that original clutch?
  19. Congratulations! Is that a winter front on there.
  20. Can the carter “bypass circuit board” be adapted to aftermarket pumps?
  21. Possibly the inside snap rings are missing
  22. This reminds me of an old pickup I used to have. I had changed the box, the hood and both doors. It had 7 different colors on it.
