Everything posted by Royal Squire
W-T ground wire mod - Popping 150A circuit breaker
Does it help if the engine is well lubricated?
Terrible noise coming from furnace
That’s the most elaborate mouse trap I’ve ever seen!
Max VP44 Fuel PSI
Doesn’t fuel boss pressure usually go up with engine rpm?
Spare tire winch
I have a bolt with a cheap Chinese 1/2” drive socket welded to it, that I keep in the toolbox.
Been chasing TC lockup issues for awhile
I believe smarty is the only 2nd gen tuner like that, but it can be uninstalled. At least that’s my understanding.
Unmarried tuner??
Used Pacbrake install
I have attached the number for an air switch that someone else here used for 2 whl low. You can find it on amazon. air switch suitable for vacuum: MJTV-5/Clippard
Great job. This may motivate me to get busy installing the used BD eb that I picked up a year ago on Craigslist. It is off of a Ford and will require adapting for v-band clamps. It is air operated and the air cylinder was stuck. I got it freed up and then moved on to some other project. Hopefully will be able to find all the parts since we moved to a new place since I last worked on eb.
Which way to adjust rear drum brakes.
If you jack axle up and spin wheel while turning adjuster it is easy to tell
engine dies when put into gear
Perhaps @Dynamic can help.
RKE programming
You might call a good lock shop. They may be able to help
If it works that is the important thing. Like the orange vacuum line.
350-400hp 24v Auto
All body parts and interior on 1500 will interchange so sounds like a good deal to me.
Group 31 Battery Modifications to a 2nd gen RAM
Got any photos?
coronavirus protection
Wondering if “do-it-yourself” bidet installation kits are flying off the shelves since t.p. is in such short supply?
Drove right thru a milestone
Curious what the blue wire is.
I only have O/D when trans is “cool”
Maybe @Dynamic can help
Need fuel system help!
That kit is pretty much what I have, should work fine. You can get the needle valve locally or on line either way it is highly recommended.
More turbo questions
Might check with @Dynamic
Cruise Control Off switch on Clutch fail
I meant to say the clutch safety switch or whatever it’s called
If I remember correctly mine revs also and I have functional neutral safety switch. If I’m slowing to downshift anyway I just touch brake
I use brake pedal
Abs nightmare
Most scanners won’t read 2nd gen ABS codes. Gotta spend some serious $$ for snap-on or similar.
APPS reset procedure
Look for “Vulcan Performance Draw straw 5”. Vulcan is an advertiser on this site. It will replace in-tank pump. Either need to tilt bed or remove tank to install. If you look in articles section I believe there is an article with photos of the install.
Parking brake failed
Could get one in a salvage yard
