Everything posted by Royal Squire
Please prayer for MoparMom
So sorry for your loss Mike. Will keep you and yours in our prayers.
Tire recommendations
I had a set of Hankook Dynapro, if I remember correctly, on my company pickup, a 2015 Silverado 1500 that went 101,000 miles. I carried a lot of tools so was heavy for a 1/2 ton. Tires would have gone farther if I would’ve rotated them regularly. Have Toyo open country on my Dodge. Unsure of mileage but they seemed to wear quickly. Next set will likely be Hankooks.
Rebuilding the 97'
Maybe you should consider a complete cab replacement
Can't boost above 22psi with the wastegate plugged
Could have a boost leak
What deer?
Guages?!
I too have pillar gauges, Isspro EV1 style. Ordered them from either Vulcan or DAP, can’t remember which, both are sponsors on this site.
P1689, VP, ECM, TIPM, AND DASH...UGGGHHH
I believe the mileage is in the cluster not the ecm
Hard starting, no starting
Got any codes?
Water/Fuel separator PROBLEMS
How much fuel pressure do you have?
CAD Questions
Are the vacuum lines there?
2000 5.9 24 valve Cummins PCM won’t let truck run
Codes?
New Headlights for Big Blue
I’m curious as to the reasoning for the flashback leds. In the past it has been an advantage to have the amber park lamps when snowing heavily or foggy and very poor visibility I’ve turned off headlights and had better visibility with just amber park lamps. Anyone else have this experience.
Got another mustang
Nice car. Looks like summer there!
High Idle
Moparmans high idle switch is very handy. I use it often.
Fass Heater
Could leave it running or somehow circulate fuel
Replacement dash
Got any photos?
Air bags
There is a post on here somewhere that recommends Firestone F2220 IIRC.
Tool Talk...
I have nebo tempra brand IR thermometer. It has adjustable emissivity and a flashlight. Haven’t used it a lot. Did use it recently to check oven temperature.
What is the highest known power with SO pump
I think maybe you didn’t count your zeros!
VP44 Adrenaline Quadzilla used on other than Cummins
Not sure that ecm is Dodge since you can purchase it through Cummins
Standby generators
Propane is a lot cheaper than gasoline or diesel, at least right now. Might consider a duel fuel generator although I don’t have any experience with one.
Oil change interval
Guess I’m colorblind
Oil change interval
What’s your mileage now?
