Smoke/vapor from vent tube.
@Alexio Auditore is right about checking for a vacuum leak, but using HVAC system for troubleshooting may not be conclusive because there is a check valve in the circuit so the HVAC system can hold vacuum after the engine is shutdown. There are other vacuum circuits that could be leaking - the transfer case, the CAD unit, and cruise control if you have an automatic transmission. I woud go directly to the vacuum pump, disconnect the vacuum hose and place a cap or plug on the vacuum pump inlet. Start the engine. If blow-by decreases, you will know that you have a vacuum leak. If blow-by remains unchanged, then a vacuum leak is not the source of the problem. - John
Towing...Your Experience Is Appreciated 98.5 24V 2500
That would work!
Sure the top two gears are the same - so is first gear. But, sometimes there are conditions such as @keithb7's 3.5 mile, 30 mph hill that makes having three gears (instead of two) to work with between first gear and the 1:1 gear a real benefit whether going up or down that hill with varying loads. Sort of like the benefit you mentioned about improving the final drive ratio when you went from 265 tires to 245 tires. So, I still think the six speed transmission is the best choice for towing - just my opinion. Personally, I wish there was at least an eight speed manual transmission that would just drop right in. And yes, @dripley, I also occasionally go for 7th gear. - John
I think you added your ratios; you need to multiply. 2.45 x 3.55 = 8.70 2.45 x 4.10 = 10.05 My personal preference for safely towing in hills is with a manual transmission and an exhaust brake. The manual six speed gives you the best performance. You will have a gear for every kind of hill (up or down) and you will always be operating the engine in an RPM range that will be do the job efficiently. One option for you is to sell your truck and buy a truck with a manual transmission and install an exhaust brake. This would be a very effective way to solve your issues with your truck. The other option is to continue to put money into your existing truck by beefing up the transmission and torque converter and installing larger brakes. You can only hope that whoever builds the transmission for you can lock up the torque converter in every forward gear with controls that are simple to operate. In the end you still have only four gears to operate the truck and you will never optimize the performance capability of the Cummins engine for going up and down hills. - John
@keithb7, you posted, "I live up a mountain. The road home is pretty steep. It's a slower 2 lane winding road. Speed limit 30 mph. It's about 3.5 miles from the start, to my driveway. I gain about 1100 feet elevation over the 3.5 mile climb home. Average road grade over the 3.5 miles is 10%.". I could be wrong, but my math shows that your average grade is 6%, which is still steep and would be of concern. In my opinion, your 4 speed automatic transmission is the root of all your complaints. Even if you beef up the transmission and make it lock up in all four gears, install bigger brakes, and equip your truck with a exhaust brake, the transmission still only has four gears - of which one gear is an overdrive. Not only that, first gear and second gear ratios are 2.45:1 and 1.45:1 respectively - not much holding back power. Below are gear ratios of most Dodge Cummins transmissions. You will see that the 5 speed manual and 6 speed manual transmission are much more suitable for towing. The 6 speed manual transmission has four underdrive gears with more suitable gear ratios compared to only two underdrive gears in the automatic transmission. Also, I don't think you posted your differential ratio or tire size which can impact performance. For example, a 3:55 differential ratio with larger than stock tires will negatively influence towing uphill and downhill. - John
New Death Wobble Issue – 2001 3500 EX Cab Dually 2WD?
Don't forget to check for excessively worn shock absorbers. They may not leak and may appear to be normal, but if one or both of them collapse or extend easily without resistance, that can definitely contribute to your condition. The only way to check the shock absorber's condition is to disconnect the shock absorber at one end and operate it by hand. There should be lots of resistance, especially while extending. Death wobble is usually generated by several worn steering / suspension parts and having large tires and wheels on the truck. What is your tire size? - John
The title says, "2001 3500 EX Cab Dually 2WD?" with a question mark. Is this a two wheel drive or a four wheel drive truck? If it is a two wheel drive truck, then it is has an independent front suspension - no track bar. But it does have upper and lower ball joints and it does have upper and lower control arms. Are any of these loose? Are you truly experiencing the death wobble? If you are, you probably think that your truck will leave the road and you won't live to tell about it. I didn't think that two wheel drive trucks had a problem with the death wobble. - John
Front Brakes
Actually, the most important benefit of an exhaust brake hasn't been mentioned - it is its ability to use the engine to hold back a heavy load on a long steep downgrade without the use of service brakes, or at least with very minimal use of the service brakes. If an emergency stop is required half way down the grade, you will have cool, fully functioning service brakes available that have not been overheated from controlling vehicle speed while going down the grade. To me, that alone is worth the 1000 or so dollars - the saving of wear and tear on pads and rotors is just a bonus. - John
2012 Ram 6.7L
I don't think it is clear in @Mopar1973Man's post as to whether or not he re-used the injectors or he installed new ones, but I am sure we will find out. - John
02 24v no start
@Mopar1973Man, in the last few days I have noticed that there are no longer any names associated with "Likes" for my posts and others that I see. For example, I have two "Likes" in my previous post, but I don't know who they are. Anyone else experiencing this problem? - John
02 24v no start
What is that red wire that has a messy connection to the alternator output terminal? If there are more wiring connections on your truck that are done in that manner, I would be thoroughly looking over the electrical system. - John
Front Brakes
Did you find the cause of the 4th gear failure? How did it fail? Just curious. - John
Front Brakes
I can't speak for others, but I have 312,000 miles on the original six speed transmission with no repairs. I replaced the clutch with an OEM clutch at 297,000 miles (failed pilot bearing). I use the exhaust brake on my truck in the exact manner that @Mopar1973Man describes. - John
Control arm adjustment ?
Not surprising. - John
Moving the lower control arm forward will increase positive caster. This will utilize the weight of the truck to improve the handling of the truck for straight line driving and to improve returning the steering wheel to center after cornering - the positive. It will also add more steering effort (especially sharp turns) and put a bit more load on the power steering and steering gearbox under certain conditions - the negative. Personally, I have set mine to 4 1/2 degrees positive caster years ago and I like it - I think it is well worth the trade off. - John
Smarty s03 today :)
What ? Are you saying my truck's retarded? (attempt at humor). I understand what you are saying about the limitations of the Smarty S03. On a different subject, is the screenshot in your photo the actual display you are looking at while driving down the road? If so, what is the size of the screen? - John
Smarty s03 today :)
@Evan, it is good that you have read @pepsi71ocean's Smarty S03 article. Another good read, if you haven't already done so, is @Tittle Diesel Performance's posts regarding what a Smart S03 representative told him. Two important items: 1. He lists the default Revo settings (torque management, timing, and fuel duration) for each software setting (SW1 through SW9). This makes for a good reference point when deciding which Revo settings you want to change, which direction you want to go, and which settings you will leave default. 2. If all Revo settings are left to default, the software in general increases torque, advances timing, and increases fuel duration progressively from SW1 through SW9. But, if you select a Revo number in either Torque Management, Timing, or Duration that is not Default (0), then those parameters stay the same regardless of software number (SW1 through SW9). My truck has a manual 6 speed transmission and the engine has RV275 injectors, so tuning for me is much more simplified and using the information from @Tittle Diesel Performance's posts, the software settings I have tried seem to agree with that information - at least for my truck. I believe @pepsi71ocean has had a different experience. Your truck seems to be a closer match to @pepsi71ocean's truck. It seems that with automatic transmissions and large injectors, the transmission shift points can be greatly affected with different Smarty settings which masks what is really going on at a particular setting. This would definitely make it harder to tune the truck. These are only observations from my point of view from reading different posts, as I have never tried to tune a truck with an automatic transmission. - John
Fuel transfer pump relocation
A few years ago I bought a used FASS lift pump and mounted it onto one of the rear cab mounts right at the front of the fuel tank. I just stayed with the factory lines and it was easy to tap into the fuel lines on the inside of the frame. I also installed an in-line fuel strainer (Napa 3270) on the inside of the frame between the tank and the lift pump. - John
PDC
@dripley, I checked where the power for the lift pump relay contacts come from on my truck. As you suggested, it comes from the battery connection at the PDC. A short distance away is a 15 amp in-line fuse. @Daleb, I can't remember if you mentioned where your lift pump gets its power, so if you haven't checked, it would be a good thing to verify. If the power for the lift pump is tapped into an existing circuit, the additional lift pump current could easily overload that circuit. Ideally, the lift pump should be fused and relayed from the PDC and the coil portion of the relay triggered by the ECM. - John
High Beam Indicator Stuck On
Since you said that you just purchased this truck, do you know any history about the truck - particularly the headlight system. * Are the headlights still OEM? * Is there one 9004 bulb for each side? (one bulb per side system) * Is it a sport headlight system? (t2 bulbs per side system - 9007 bulbs for 2 outside lamps and 9004 bulbs for 2 inside lamps) * Does the truck have fog lights? If anyone has modified the headlight system, I would start my troubleshooting there. - John
PDC
@dripley, when my first VP44 failed 64,000 miles and was replaced at 87,000 miles, it was replaced under warranty along with the lift pump and the associated wiring. At that time the factory fix was to install an in-tank lift pump and to relay that lift pump. The coil portion of the new relay was triggered by the ECM, but I don't know where the power source comes from for the relay portion that actually operates the lift pump. I was wondering if you might know. I think I might have to do some investigating - John
PDC
If the headlight wiring is OEM with a factory one bulb per side system, then all of the headlight controls (headlight switch and dimmer switch) use the ground wiring side of the bulbs to switch the headlights on and off. The headlights are fed by a hot lead. Does your truck have fog lights? I am assuming your headlights were working normally before your problems with Joint Connector #2. Try the following: * Leave the key switch off and operate the headlight switch. The low beams and high beams should operate normally. If they don't, operate normally, then I would start my troubleshooting here. * If the headlights do operate normally with key switch off, then I would be looking for something powered by the ignition switch circuit that is switching the ground side wiring for the headlights to ground. Sometimes when I am troubleshooting electrical problems I like to prove what is working correctly rather than trying to come to a conclusion that I can't prove. For me, it is a process of elimination. - John
Head gasket replacement
Good thinkin'! - John
Oil from breather tube
The two times over the life of my truck that I noticed the breather tube was messier and leaked more oil than normal, I had a vacuum leak. Neither time was the vacuum leak large enough to noticeably affect vacuum operated controls, but the excessive air flow showed up through the breather and added to the mess. Each time I repaired the vacuum leak the breather began venting normally again. - John
How do you clean your engine bay?
I use the treated wipes the guy hands me at the car wash for interior cleaning. They are white so I can see when I wipe off a dirty spot on the engine. - John
