wil440
Everything posted by wil440
  1. Have you got the nutters called extintion rebellion yet ?? These idiots caused chaos here last year, bought London to a standstill times. One time last year there was about 10 to 15 on top of a train stopping it moving, loads of other people stood there trying to get on to go to work... was pointed out on the news that it was a totally electric train ? Anyway back to rust... my truck has arch extensions and rust behind
  2. Got the tank dropped and the module out, nice and clean no water or slime, my truck hasn't got an in tank pump so fitting the drawstraw was nice and easy, got 4 days off from tomorrow night so ought to have the fuel system and the quad all done
  3. Been a government funded scheme here for ages to entice people to strap themselves up with a new car, lots of nice older cars just squashed and owners get 2k off new. Here the enviro police are really getting onto diesel for air quality, neither of my trucks are allowed into London without paying a fee, don't know what the amount is as I wouldn't go anyway, cities are banning diesel vehicles in the daytime, large goods vehicles are not yet included in this just the normal working mans car as usual, and just this week a report on the newer DPF rubbish that states when they are in regen they emit 150% more soot than an older diesel, this is one reason I'm not parting with my gas 3500, luckily I work in a quarry...... everything is diesel but the wrong colour I doubt this will change for a good while......
  4. If the USA gets onto this zero emission stuff like the uk has then more salt will get used as its a really cheap way of removing older vehicles from use, way cheaper than paying people £2k to scrap a perfectly good vehicle and pull the trigger on a new pos from china ?
  5. Everytime I'm under mine I spray it with a maintenance spray we use at work, it's a bit thicker than WD40 but could do with being thicker still. Also use a copperslip spray
  6. If it is stock then that just clips into the wheel rim. Check the valve stem is aligned with a hole then tap chrome cover towards wheel with your hand. The chrome lug nuts are fake, lug nuts are behind the cover
  7. Celsius. I haven't used 1/2 a can of deicer yet ☺ but as we are surrounded by water our coldest time is feb and march, takes longer for the sea to warm so the boffins say
  8. Boy am I glad we don't get 30 below here in the uk, only been just below zero maybe 5 or 6 times here this winter, one benefit of living on a small island right in the path of the gulf stream, but it can rain for England ?
  9. Spent an hour or so on it last night and while setting up the pulleys I noticed the crank pulley sitting too far out for my liking as the pump shaft has a flat milled on it for grub screw to locate but the flat could do with being another 1/4" longer then both pulleys could sit further onto their respective shafts so I ground the pump flat a little longer ( not worried about warranty as pump will be fine I just want the pulley to stay on) I'm going to loctite the pulley grubscrews tonight although the crank pulley uses 2 x1.5 mm allen key grubscrews which looks real easy to get to.... not! Then start dropping FTank
  10. Yes comes with longer allen screws which sit down in counterbore as the pump sits over at least one of them maybe both
  11. Got the drive hub mounted then went onto mounting the bracket onto the front of engine, it mounts onto the sump rail using the 2 middle front bolts, the bracket is shaped to sit flat to the sump flange down in the groove, got it fitted but It didn't feel right so I took it off again and noticed my sump is slightly off to one side on the holes which meant one end of the bracket was sitting on the raised strengthening lip so I need to grind a little off of the bracket in this area to allow it to seat down properly. There is nothing wrong with the shape of the bracket it's my sump that has been bolted down slighly off, the grinding won't be visible so no big deal. Something to check as while torque is only 18lbft it felt like the one bolt could have stripped in the front case,luckily I only got to 7lbft before I noticed it didn't feel right so no harm done
  12. made a start tonight after work, fitting the cranks drive adaptor, here's an easy way of holding the crank to remove the 4 bolts, I usually use stilsons, maybe you call them pipe wrenches but I broke my small set not too long ago, pictures aren't great as it's dark ish but anything will work if it has adjustable jaws 90 degrees to the handle, doesn't damage the damper as it just adds a little resistance, any size damper can be held just find bigger stilsons
  13. Thats right, I just paid 30% in import duty and Vat for the quad and assassin, but it's compound so it would be.. lets say 5k for a trans, 1500 for core, and 600 shipping, $7100 import duty is then added and it varies as each commoditiy is different but lets say 15% = 8165 then vat at 17% thats around 9500, thing is the core charge would be taxable if it was on the invoice and I'll bet shipping it back would cost more than shipping one here. Hopefully when we get out of the EU at the end of this month a good trade deal is done
  14. I wasn't annoyed just asking the question is all as being in the UK It would cost the earth to send a core back and there is none over here so while I need to do my trans I don't know what to do about a core, I'll probably just do the trans I have
  15. If 47re's are that cheap.... $ 150 ish then how come most rebuilders charge up to $1500 for a core, a pile of $ on parts I get but close to 25% on top for a150 core is an ouch. Problem for me is 47re for diesel never comes up for sale here, core or useable
  16. sorry for the hijack. but if 47re cores are a dime a dozen please get me one and ship it to the UK then I can start ordering parts for the build
  17. I haven't up to now but I have a Cat seperator to fit while i'm doing the FP and quad. Also got to drop the tank to do suction so I'll see if there is water and decide then I'd say due to using long Cat filters and the head and filter thats on at the moment being for much larger engines any water is stuck in the bottom of the filter but as the whole lot is coming off this week I'm going to do it right
  18. Here's a picture of the cat filter head and primer, the primer bolts to the front of the filter and cat have an adaptor to change the angle of the primer to suit different applications, it's basically a peice of aluminium with the same flange as the filter and primer but it is at an offset angle, I'm going to mount the head where the original fitted and where I have a Cat filter without primer fitted now and I think the primer will be just to the side of the intake tube
  19. I'll post pictures of my filterhead and primer later today..... after work. Only thing I've read is bits from the install holding reg open on first start. Like the looks of the pump and while I have read the forum posts on DTT it all looks super easy to fit Cat part numbers are Filter head 237-9312 Primer 569-4607 There is also a primer adaptor that changes the angle of the primer, part number4N-9624 I'll get pictures later One head used on ebay USA now
  20. quad and assassin arrived today also got a older style Cat fuel filter head with plunger primer that Cat used before going electric primer pump. Got to put a track on a Cat 390 excavator tomorrow at work so won't be starting the job tomorrow
  21. Just for reference now you have a good vp don't put fingers over or anywhere near loose injection lines, high pressure fuel can penetrate skin/people very easily and it's supposed to not be nice, this is more important with pop testers but if you follow the golden rule of not going anywhere near you'll not be far wrong
  22. Only to cool the ecm as far as I know as fuel in modern engines passes through the head in a common passageway anyway so it picks up more than enough heat but I only do large diesels now, well Cat C7 up to C32, sililar size volve,komatsu etc
  23. Most all large diesels I see ( up to 32litre) ecm is on the block but everyone is fuel cooled even before aftertreatment which do run very hot
  24. If you are close to Cat dealer they sell single sample kits right up to 12/or 15 sample kits. Don't know cost of these kits as I buy 100 sample bulk kits
