Everything posted by IBMobile
Running lights
Do you have 12v at the black/yellow coming from the headlight switch to the front park/turn signal assembly? Also ohm test the black ground wire.
1997 Cummins electrical issue causing relays to tick
I don't have a diagram for a '97' but in a '99' those relays and the transmission are controlled by the Powertrain Control Module. Check the ground wires for the Powertrain Control Module. They are black with tan stripe at the C connector pins number 31 and 32. They ground at the right side battery. They go through a splice and a connector before grounding at the battery.
ECM died. Need help
I think you need to remove the engine wire harness, do a full inspection and repair any splices before condemning/replacing any more components.
ECM died. Need help
22.2mV (0.022V) is a good reading. Yes
Incorrect boost values.
The 14 psi at idle is atmospheric pressure where a dash mounted gauge will show 0 psi. When I put my code reader in live data mode it shows the atmospheric pressure also at key on engine not running where the dash gauge reads 0. The ECM has to take into account the loss of pressure as the truck goes up in altitude so that it can decrease the fuel for a better burn. So what you are seeing is normal.
Ode to the leak
I think these will help.
47re
Raybestos Pro Series intermediate band http://aftermarket.raybestospowertrain.com/pro-series-bands
5er battery wiring
So, does your trailer has the euro 13 pin plug and you need to wire the truck or is it the other way around? Can you use an adptor plug? https://www.towingandtrailers.com/products/trailer-parts/trailer-electrics/13-pin-7-pin-trailer-converters/
5er battery wiring
What is the amp draw on the system when just recharging the batteries or are you building this for an add on latter? 40 amps seems a bit high for just recharging the batteries and need 8 AGW for that load size. .
47re
The lock up clutch failed in the torque convertor. There was no metal or clutch material in the pan so it did not burn up; it just would not fully engage.
47re
Here's the build sheet and I upgraded the torque convertor to a Goerend 15SS Air temp 91°F Transmission fluid temp 165°-190°F Line pressure, transmission in drive : no throttle stopped 85 PSI light throttle 2ed gear 105 PSI light throttle 3ed gear 110 PSI light throttle 4th gear 120 PSI @ 2200 RPM W/O throttle 1-2 shift 180 PSI @ 2800 RPM W/O throttle 2-3 shift 175 PSI @ 3100 RPM W/O throttle 3-4 shift 150 PSI W/O throttle 4-3 shift 150 PSI 100% throttle 4th gear TCC locked @ 70 MPH 160 PSI 0% throttle 3ed or 4th gear TCC locked down hill slowing 100PSI reverse gear stall test 330 PSI This transmission is putting power down that was wasted with a stock build. I now have the power to the tires to brake them loose or tow my 5er with the boat behind it up an 8 mile 6% grade at 65 MPH with throttle to spare. Thanks Jon.
advice on rv or 5th wheel
Get those headache tablets ready.
Real head banger, built ats transmission
The OD/TCC solenoids come with all the internal wiring needed.
We need pics of the 5er and hitch.
- Morning Pic For Today...........Post A Pic around your place.....
- p0108 code
- Speedometer jumping
@Mopar1973Man had an ABS problem. He changed sensors and wheel bearings with no luck. He found the left front wheel tone ring bad/loose.- advice on rv or 5th wheel
Is that £ or $. What makes it "Euro truck towable"?- Mechman alternator
Have you seen this?- 47RE Transmission Temperature Port?
Case in point, When the torque convertor lock up failed in my transmission I noticed the temperature elevated from a cruising normal of 160°-170°F to 190°F and when going up long 6% grades, 5-8 miles long, the temperature would rapidly increase from 190°F to 250°F. After stopping half way up a grade and running the engine with the transmission in neutral the temperature would keep increasing, sometimes to over 280°F before it would start to cool. It would take up to 20 minutes to cool to 190°F. If the temperature probe was in the oil pan I would have never seen that rapid temperature increase due to cooling from the heat exchangers and temperature dilution when mixed with the cooler fluid in the pan. There could have been a good chance of the transmission being cooked before the temperature sensor in the transducer saw the overheat problem and turned the warning light on in the instrument cluster. NOTE: The temperature sensor is in a part of the valve body, just before the governor solenoid, and sees very little fluid flow.- 47RE Transmission Temperature Port?
- Can't sleep bad ideas in my head
Take the money you would dump into this project and invest it. When you retire you will be able to buy one of the new electric trucks, because diesels will be banned by then, and pay cash.- Engine Coolant Temperature Mismatch
- Second gen long gun safe storage
Can you have something fabricated that would bolt under the back seat? Say 28gauge sheet metal with a hinged top, line it with felt and add hold down Velcro straps to keep the guns in place. Incorporate the lock style of your choice. - Morning Pic For Today...........Post A Pic around your place.....
