IBMobile
Staff
Everything posted by IBMobile
  1. Looks like you have the T-style steering which is the heavy duty type. You can go to the parts lookup article below and on pages 380-381 find the OEM part numbers with description. After the part number and quantity, the numbers in the line column will be 7,8 and in the description column will be [Z7B,Z8B] for heavy duty. With those OEM part numbers you then can cross reference to the Moog part number. Open the link below and type the OEM part number into the "Search by Part Number" box, click on the search tab and the Moog part number will be displayed below. https://www.moogparts.com/find-my-part/find-my-part-results.html?parttype=&apptype=AUTOMOTIVE&options=2000~Dodge~Ram 2500&values=2000~Dodge~Ram 2500
  2. Can you post a picture of your steering parts so someone can tell you if it's T-style or not. Rock auto has a selection of Moog parts with the OEM part numbers in the cross-reference section. https://www.rockauto.com/en/catalog/dodge,1999,ram+2500+pickup,5.9l+l6+diesel+turbocharged,1377569,steering,tie+rod+assembly+(inner+&+outer),7425 https://www.rockauto.com/en/catalog/dodge,1999,ram+2500+pickup,5.9l+l6+diesel+turbocharged,1377569,steering,center+link,7276 Here is an article that might help you.
  3. I hope all is well after the hospital stay. It's good to hear you have the truck running tip top again with out a lot of cost. One thing though is that the fuel pressure is way to high. You want to get that pressure down to about 20psi at idle and no lower than 14 at WTO.
  4. Sitting down with my first mug of many for today.
  5. @dripley getting his morning cup Morning @JAG1 the "Woodpecker Whisperer" Morning woodpecker at my house.
  6. Put some shim washers under the bed front mounting points to get that bow look out.
  7. Washer nozzles go bad, plug up, when hard water deposits form in them or an alga blockage . If you can take them off, with out braking them, soak them in CLR then rinse and blow air backward through them. Some times you can run a very fine strand of wire through the openings.
  8. He smiles when he's going for the beer. @KATOOM this will show you a good place to put the filter.
  9. Yes they are easy to reseal. On other module vehicles that use the Saginaw power steering pump I've seen leaks due to stress cracks at the bolt holes in the fluid reservoir. With the miles on that pump it might be better to get a rebuilt unit. Get one with a lifetime warranty.
  10. They must have shipped that last one to the same address as the first two … La La Land.
  11. It was a typo. My head lights are not sport so I have only the one blub, 9104. I think you could use them, also, in the low beam position if the terminals in the blub connector are moved. If they're 9104 they should be the same, 80/100 watt. I found these on eBay https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=9104+flosser+bulb&_sacat=6000 None, other than a twitch in my left leg.
  12. You didn't have this problem and no codes before the VP44 was replaced? Is this right? If so then you have a wire problem probable in the harness near the VP. Open the harness near the V Pand check for a bad power/ground splice or pinched wires
  13. I use an LED head lamp like the one below. What ever you're looking at be it under the hood, truck, dash or the brakes and tires it will be illuminated. It works great day or night and both of your hands are free. No extra wiring needed and it fits in the glove box, door pocket or under the back seat. You can also use it if you need to work on a trailer you towing. Good ones sell for $20-$40 and get the one that has 3 AA batteries; they're brighter and stay lit longer.
  14. I doubt the wires running close to each other is causing this but the grid heater put a very large load on the alternator which would produce a higher ac voltage signal. Try this, disconnect the grid heaters main power leads from the left battery positive clamp and see what happens.
  15. Manufactures are only required to supply parts for vehicles for 10 years; after that it's at their discretion what parts to supply. They will then supply the fast moving, money making parts. I bought my truck at Jack Powell and have a wholesale parts account with them. I'll make sure I ask for Nolan next time I'm in there.
  16. The green/white wire behind the AC controller. Leave a little pig tail (2-3" long) from the plug in case you want to use that function again.
  17. Glad to have you here, where people come to tell stranger than fiction stories about their trucks and other things. It'll be nice to have another tech who can enrich us in the latest from Mopar and bounce ideas off of. I worked in dealerships for 24 years. If the dealership sells unauthorized aftermarket parts or modifies their products in a nonprescribed way corporate will put the hurt on the franchise from pulling cash bonuses, reducing car inventory allotment, to revoking the franchise, The auto manufacture only makes money when they sell their stuff.
  18. Welcome to the site. I don't know how much Cummins food there is. Most of use like pizza and beer, chicken wings or the lobster buffet but it's an all you can eat forum. Truck repair with RV parking Reasonable Rates Call now, Operators are standing by.
  19. Never mind... I see it now.
  20. Now the rest of your truck is going to be jealous and want a face lift. Don't forget to put the felt isolators on. From whom did you procure it?
  21. The PCM should not have any influence over the regulation of alternator voltage when an external regulator is used but the alternator voltage will have an influence over the PCM. Maybe the external voltage regulator is going/went bad.
  22. I changed out a set of bald 265/75 R16 Goodrich KOs for slightly used 245/75 R16 Michelin a couple of years ago. I use the truck 90% of the time pulling my 5er and have gone on two 7,000 mile trips this last year with this size tire. Yes, the sweet spot for towing with a 4.10 is right around 2,000 RPM. At that RPM I cruse in 4th at 65 MPH indicated. The truck pulls very well when going up hills and I drop down to 3ed, this keeps the exhaust temp down. The change to a 245/75 R16 tire will increase your finale ratio to 4.26 and the speedometer reading at 65 MPH indicated will really be 62.4 MPH https://www.discounttire.com/learn/tire-size-calculator https://tiresize.com/gear-ratio-calculator/
  23. The same tools at Harbor Freight cost more and their quality is barely good for a do-it yourselfer. https://www.harborfreight.com/automotive-motorcycle/refrigeration/3-cfm-two-stage-vacuum-pump-61176.html A mechanic starting out needs to buy quality tools that will last a long time and in tools you get what you pay for.
