c farmer
Everything posted by c farmer
  1. Stick with the green. If you dont get all of the old green out and put pink in it, it will turn black. they dont mix well.
  2. My timbos apps works alot better then the factory one did, even from new. Alot better than new.Sent from my DROID3 using Tapatalk 2
  3. x 2 on the timbos apps, works great and easy to follow instructions.
  4. I ran the edge comp and the tst comp. The tst felt way stronger but I had a timing box too.
  5. I am worried about the sump leaking. Any advice.Sent from my DROID3 using Tapatalk 2
  6. I think I am going to use a fuel sump. Sent from my DROID3 using Tapatalk 2
  7. I wouldnt get it. It only fuels to a higher rpm not extra power.
  8. My bad apps acted just like that other than it threw a code.
  9. Man that is a awesome room. You must have a beautiful house.
  10. Let us know how you like it. I am thinking of getting a mechanical fuel pump.
  11. Should be able to put a tee in the feed line to the vp.
  12. I use the mopar stuff.Sent from my DROID3 using Tapatalk 2
  13. The airdog 150 has a elbow that threads in to the vp, right? Is so then you can't use a tapped banjo bolt. Sent from my DROID3 using Tapatalk 2
  14. Can I run a snubber and a needle valve?Sent from my DROID3 using Tapatalk 2
  15. Did you put the additive it in.Sent from my DROID3 using Tapatalk 2
  16. I have one to. It works perfect. Sent from my DROID3 using Tapatalk 2
  17. Thanks Sent from my DROID3 using Tapatalk 2
  18. I will. I was going to install it tonite but I have to get a big drill bit to get that big steel line through the firewall. I don't know any other way to get it through.Sent from my DROID3 using Tapatalk 2
  19. In the second pic you can see a very small hole that acts like a snubber.Sent from my DROID3 using Tapatalk 2
  20. Sent from my DROID3 using Tapatalk 2
  21. I do all trucks that way. I work at a dealer and have done many 4th gens with all the garbage that the 6.7l has.
  22. I have a mechanical gauge. I will try it the way I want and if I dont like it then I will put a needle valve in. I will not have to change anything to install a needle valve. Atleast I dont think I will.
  23. My banjo bolt is also a snubber valve. I got it from tork tech. I thought I would try it. The steel line came with the used gauge I bought.
  24. I need to make a smoker. I have a masterbuilt now and it works, but I need a real one.Sent from my DROID3 using Tapatalk 2
