Everything posted by Doubletrouble
Oil change interval
My buddy has a 2013 with the 6.7 (he's the one that talked me into mine) and he changes his every 5000 I believe. I thought it was a bit excessive but it's his truck.
Oil change interval
One needs to save some where, maintenance can be expensive.
Oil change interval
Where would I take the sample for analysis? And what does that results from it tell you? Sorry, new to diesels, never did this on a gasser.
Oil change interval
Never heard of that brand. Are those available at any common auto parts store or online?
Oil change interval
I honestly do not tow much at all. My truck is truly overkill for what I need. I mainly drive to and from work about 35 miles round trip, about 20% is "city" . 7500 miles would probably last me about 5 months maybe?
Oil change interval
It won't be long and it'll be that time. I recently bought this truck, previous owner used regular rotella. I am considering full synthetic rotella oil. In the manual it says 7500 miles between changes, would that extend if synthetic is used? For those of you that run synthetic, what interval do you change yours? Just a curious question to see if the extra expense has more advantage than just better oil. Thanks
rear drum setting
They make a tool for this as well. I used to have one but it was stolen along with my entire top tool box years ago. Been wanting to get another as they are handy.
Squeal/siren noise! Please help!!!
With the truck off that would isolate the noise to anything moving at the time. Axles, brake drums/rotors, wheel bearings, drive shafts. I may have forgot something but you get the picture. Check anything that would have been moving with engine off in neutral.
May be a stupid idea but, could you have a buddy tow you in neutral, engine off to listen for the squeal? That way it will isolate axles, u-joints and carrier from engine/trans. Just an idea... I listened to the video again and again, could it be a leaking rubber coupler on the boost side? Maybe leaking just enough to whistle? Just throwing ideas out trying to help.
Newbie, changed fuel filter today, have questions
I've been looking at fuel pressure gauges, they are more expensive than I thought for what they are. I'd like to get the trio on the A pillar eventually. I may not need them with a stock motor but I do like to keep an eye on things.
I agree it is to far from the tank. I'm new to Dodge and Cummins (in dodges at least, I drive truck for a living). What would be your recommendation as far as fuel delivery and a reasonable fuel gauge? I'd like to have the pods on the pillar but it's not in the budget at the moment, been a little slow at work.
Upon further investigation, the pre filter I referred to was included with the FASS kit for filtration before the pump. It is a screen type filter to catch any debris from the tank. I found a video of a FASS install online that included this filter. Sorry, just a newbie to Cummins trying to get an understanding of things. I typically do all my own wrenching but this is a new ball game to me with the diesel. Only other diesel I have ever worked on is a 1973 ford 5000 tractor non turbo, and it was basic stuff.
There is a FASS DRP lift pump on the side of the block, that should be adequate for a stock engine correct? As far as the pre-pump inline wouldn't a canister type be more restricted? I was thinking (through research) a Napa 3270 inline mesh filter rated at 140 micron. Bad idea? I did check fuel pressure before and after filter change, at idle before 17psi, after at idle 18psi.
Door misalignment, how to fix this?
LOL, maybe the bear wanted to go joyriding?
I kinda thought the same thing.
On the quad cabs the striker is attached to the rear door. If I move that inward that would move the entire door inward. Looks like its fine until you move up to the frame around the window.
I know you can adjust door hinges and such but I don't believe this is the case here. I have pics from down the side of the body bottom, middle and top of the door to show what I mean. Not sure how to go about adjusting this. Roll window down, put a wood block in the door and push on the top portion only?
I am a newbie to Cummins diesel trucks so bare with me and my questions. I changed my fuel filter today, once the old filter was out I noticed debris in the bottom on the filter housing so I cleaned that out best I could. I had to drain the housing so it took a few key cycles to prime again but she did restart. While doing this I noticed another inline filter before the LP that I'm sure is not factory. See pics below, before and after cleaning out the debris, last one you should be able to see the inline filter down near the frame. Also, there is what seems like a larger line from the LP to the filter housing. Is this just an adapter or is it what is considered a "big line kit"? I'll post a pic to hopefully show this blue line I'm talking about. Thanks in advance for any replies.
New to the forum
I feel I got lucky on this one. 99% stock. So far the only after market piece I have found is a FASS DRLP ( I believe that's direct replacement lift pump, still learning the terminology). She runs nice and smooth so far. Has a couple of issues to address, a little rust repair needed as well. I have a few things planned for it once the weather gets nice again, nothing crazy here though. I just need a good reliable truck that will pull our 30' camper wherever we want to go, it will also be a daily driver unless it's warm enough to get the motorcycle out. Lol I won't plug up this thread with questions, I'll toss them in the second gen section later, and thanks for the compliments! I'll post a few more pics below.
New to the forum
I've been lurking for a few days trying to learn what I could about my recent purchase, a 2001 Dodge Ram 3500 4x4 quad cab with 8ft bed. So far I love the truck, been needing to upgrade for a while and finally pulled the trigger on this one with only 140k miles and a 5 speed manual. Nothing fancy about the truck, manual windows and locks, basically a work truck but I am fine with that. I'll be posting some of my questions later in the 2nd gen forums but for now just wanted to introduce myself and my truck a bit.
