Doubletrouble
Staff
Everything posted by Doubletrouble
  1. Omg! Lol I will try redoing it but coating with paint and or clear coat when finished. At some point I will be replacing some sheet metal also. Rockers, floor from bottom of the firewall to the front seat mount and the center section of the bed between the wheel wells. I think the goose neck hitch contributed to that rusting.
  2. It'll get worse. I don't claim to be a "prepper" but the local bass pro says their ammo shipments have been frozen. Most local stores like Wal Mart or Meijer are out as well. Toilet paper is hard to find along with anything to disinfect. Restaurants are now closed to dine in customers, drive through or carry out only. My sister in law is a waitress, she is now off work until further notice with no income.
  3. Not to my knowledge. I believe there is more to this and we the public are not being told. OR, it's a big political game being it is an election year. I'm not sure which of these it is yet but the plan will unfold before us either way.
  4. Just have to worry about others looting your place and taking you food stores.
  5. Whatever works lol. I won't leave it that long but i do want to test it. Right, I definitely will make sure it's holding pressure at WOT. I won't be towing anything heavy anytime soon though, have to test again under those conditions.
  6. I think I'll do that just for piece of mind Eventually I will upgrade to 3/8" line, better fittings and relocate the pump to the frame for a pusher set up. Should maybe get a bit more pressure, also more volume and more stable that way. Not doing any huge hp mods, possibly larger injectors (+40 to +75's at most) not planning on a tuner just yet.
  7. Which hold true with other illness such as the flu. Elderly and weak immune systems have the issues. I don't view this any more serious than a flu outbreak at this point. People are just crazy
  8. Being that the pressure before the VP is only 20psi or less could I extend my test gauge hose with a Barb fitting and get an accurate reading? I could let it hang out from under the good just for testing around the block. Remove it when done.
  9. Funds will loosen up before long. Just came off a layoff at work not long ago and now we are saving for a vacation in mid April. Once that's behind me I'll be able to get some things done. Just have to be a little conservative, the reasoning behind getting a diesel truck was the reliability. If the wife sees me point a couple thousand into right of the rip she will flip. Lol She knows I will maintain and modify things as time goes on just not all at once. With the above linked kit will I also need a draw straw? Or will the factory pick up do fine?
  10. I have some surface rust in different areas of my 2001 3500. I have tried to address some of it once and failed, the rust came back in a month or so. I used a wire wheel to remove any loose light rust, had pretty clean metal when finished, sprayed 2 coats of "rust converter" to stop any that wasn't removed. Then sprayed 2 coats of primer over that. The rust came back. I am not a body man but did this happen because I did not apply paint to seal the repair? I thought the primer would do that but I guess I was wrong. One day I would like to repaint the truck but for now I just want to do some touch up and fix any thing I can to keep her looking decent. Thanks for any input.
  11. It's sad to say but most people are sheep, they see one person do something so they have to do it. Then it keeps on snowballing into a cluster **** like we have now. It's disturbing. Luckily there are still a few good folks out there, the wife saw a post on Facebook directed towards the elderly offering toilet paper to them for free from an individual that was willing to hand out from his own supply. Also, our schools in Ohio are now shut down for 3 weeks, low income families that receive free lunches for their kids were worried. The local McDonald's owner offered up free lunches to people that can't afford it. It's nice to see there is still some good people out there.
  12. The kit I linked has the T included along with the 3/8" lines, fittings, pump bracket and harness extension. I believe that is the Vulcan kit in the link at DAP
  13. Lol, I've done stuff like that to. Just waxing a hot rod adds 50hp and makes it more aerodynamic. Less wind drag because of the wax I guess. Would it be safe or stupid to maybe get a mechanical fuel pressure gauge until I get the funds for a 3 gauge pod setup? Probably end up with glow shift. I know they aren't the best out there but economically that's probably where I'll get the trio. Would this kit work to re-plumb the fuel system in 3/8" line and move the pump down to the frame in front of the tank? https://www.dieselautopower.com/vulcan-pusher-pump-system-for-1998-5-2002-dodge-cummins-3-8
  14. Since I fixed it she seems to sound a little different. Maybe it's in my head but seems better
  15. If I could find a way to extend my test gauge hose and leave it sticking out of the hood just for testing purposes that would at least ease my mind.
  16. This was the cobbled mess that was in there. I don't know how it had pressure to be honest.
  17. I set out to change the pre lift pump filter today. Ordered a wix part# 33270 from Amazon. When I went to change it I found a mess from whom ever installed the FASS ddrp. They cut the original hard plastic line and slipped a loose fitting rubber line over it and installed the included filter. It had to have been sucking air in. Question is, could I just go get some of the correct size rubber line (for fuel of course) and go from the quick connect fitting on the ddrp to when the plastic line turns into the aluminum hard line and install my filter in this rubber line? Truck is down now so I need to get it fixed. See pics below. Just dodged (pun intended) an expensive bullet. The hard line was cut to adapt a screen filter pre lift pump. The soft like used was the wrong size and had to have been sucking air in. I cut the hard line back a bit more and used some biofuel approved line of the correct size and spliced in my new filter. The line I had fits right to the hard line and I also installed spring type hose clamps to ensure an air tight fit. Crisis averted! Checked fuel pressure after the install, at idle I'm at 16-17 psi. While revving the engine and holding it a 2000 rpm it holds steady at 12psi. I know that isn't the most accurate with no load on the engine but I will get gauges as soon as I can.
  18. Luckily we don't have that in Ohio yet. So if I understood all that, by running a bigger injector you can deliver the same amount of fuel faster than with a smaller injector which essentially changes the duration of the fueling event. Now, am I correct in thinking that by doing this it affects the egt by burning faster since the fuel is delivered at a more optimum time during the compression stroke? Now, say I put 100hp injectors in a stock engine, will there be a 100hp gain with no increase in boost or otherwise? Or, will there at minimum need to be an increase in boost pressure to add the needed oxygen to burn the extra fuel to make the expected horse power? If so, is there a way to increase boost without a tuner? Or, would starting down this road with the bigger injectors begin a string of mods that would need done to compliment the previous mods?
  19. I'm new to this computer tuning stuff. Now my head hurts.
  20. I have to ask: What are the numbers that you use when referring to the turbo? i.e. 54/60/12
  21. I would like to go bigger than the rv275's but in reality I don't know how soon I would spring for the tuner ($700 is a big investment, I might be a little on the cheap skate side) or bigger turbo. Then at what point do you have to think about head studs and such? I would like a bit more power but don't want to sacrifice reliability or over complicate things.
  22. Have you tried any penetrating oil on the pivot points? Carb clean as mentioned above would clean out the carbon and soot as well. Just keep working with it, it will free up eventually.
  23. I hope and pray for her and you. Hopefully they will find the cause of all this and be able to cure or at the very least control it. Keep us posted God be with Eileen and you Mike.
