Everything posted by Doubletrouble
Moisture in headlights
They look awesome, I'm just not ready to part with the much $$ for the headlights just yet.
Covering as many miles as you do you know what I'm talking about. It gets very annoying. I work night shift so my entire work day is in the dark covering anywhere from 200-500 miles a night. I also live in the country so I want good lights on the way home to avoid animals. Deer vs. truck is never good.
Right, I already figured I'd be readjusting once I replace the entire assembly anyway. Usually they aren't adjusted properly from the manufacturer. I don't like blinding people, I drive for a living and it is one of my biggest pet peeves. I don't mind that someone has great headlights, nice and bright but put them down so I can see to! Lol
I have considered those assemblies with an LED bulb I believe I read somewhere that LED's need a certain type of reflector or something. A buddy runs LED's in his factory housings on a '14 Chevy truck and likes them but I've never been in it at night myself to tell.
Have been looking at those same lights. Going to have to wait until I'm back to work though. I was thinking those assemblies with silver Star ultra bulbs.
RUST: what is everyone doing to prevent it?
I've used a couple different brands of the so called rust conversion products in spray cans and so far I have not been overly impressed with them. Recently I did the bottom of the passenger door, it had some surface rust so I took a wire wheel to it on a drill to remove any loose stuff, the 2 coats of the "rust converter" and primer. The rust is showing through the primer already after about a month. Might be my fault since I didn't seal it with paint or clear over the primer though. Not sure.
New Headlights for Big Blue
That's just mean
Be alert!
A smart car would have bounced off of it and changed directions like the old wind up toy cars from years ago.
I would think that a truck in Regen would emit more in that amount of time than a healthy no emissions diesel would if it was turned correctly. I remember the cash for clunkers as well. A lot of decent older vehicles got smashed because of that. They try to blame all the emissions and global warming on the common working person and we pay for it and yet the military runs all over the world with their diesel vehicles and no def or dpf systems in place. (Last I heard at least) We are having a very mild winter here in North West Ohio, if this is a result of global warming I'm all for it! Lol
Not only is the salt bad but now they are using the liquid calcium chloride garbage as well. That stuff will eat through an aluminum fuel tank (like a semi truck) in a matter of a couple years if left unchecked.
Be alert!
I've had that happen at work. A large bird of some sort flew out if a ditch right into my windshield and broke it.
Random wire near abs unit not connected
Kinda thought it might have something to do with a brake controller or something. My suburban had a bundle of wires in about the same spot to wire in a trailer brake controller. It don't seem to be hurting anything so I'll leave it for now.
I saw a video and did some reading on a product called fluid film, never used it myself or known anyone that has. It's a thicker oil in an arosol can. Also saw one of those truck shows on TV highlighting another product, the name escapes me though. I like the look of that much better since it has a black color to it but that stuff has to be applied at one of their certified vendors. It didn't give a price on the application. A lot of DIY receipes out there as well. I'm not a big fan traditional undercoatings because I've seen in the past on my own vehicle how they get scratched then moisture gets in and compounds the problem your trying to avoid.
Is there a way to dry these out for good? It's been very damp around here lately, plenty of rain/fog and these have gotten worse. Don't have the funds to replace them at the moment so if there is something I could do with these for the time being to get by for a while.
I found this random black wire that was just sitting on top of a bolt near the abs unit. Not sure what it is, looks like maybe a ground wire but not sure. Anyone know what it may be for? It seems to split from the harness just before the abs. See pics, hopefully you can see where it comes from.
Isspro fuel pressure gauge
Yes it is. Union job to so there is a level of security in a sense as well. I'll just ride it out and see what happens. Unemployment will get me through for the time being.
Mine radiator is already like that. I have plans once it warms up to flush the cooling system, pull the radiator and flush it out separately, then degrease it. Going to replace the thermostat and maybe the water pump as well just as a precaution. My engine temp doesn't stay where it should and the heat from the vents could be better. Driving down the road she will be a hair over 190° on the gauge but when I stop even for just a red light it will start to drop and level off about 170° at idle. I have plenty of maintenance to do simply because I'd didn't know the previous owners and their maintenance habits.
So far other than the breather can in front of the engine I believe mine is leak free. Very little oil under the truck from that. From there back she is dry as a bone.
Moper1973man, That's basically where I want to go with my truck. Longevity and reliability. If I pick up some extra horse power and economy along the way so be it. Will be staying with the stock tire size and don't really use my truck to its full potential. Just wanted a long lasting platform hence the Cummins
I've been hanging out here quite frequently, just reading and learning about my truck and what others are doing. Very interesting to me and a great bunch of people here.
JAG1, I don't want to jack the thread so I'll be quick. I drive a car hauler for a living, automotive industry is up and down with certain times of year. All in all the job/pay and benefits to me are worth waiting for. They project a 2-4 week lay off tops. That's what I'm hoping for. Fingers crossed! I really do like the job, hate to jump ship.
Being a 2nd gen owner and living in Northwest Ohio I have some rust on my truck. Most do around here. I have been reading, searching and reading some more about rust prevention. I have some rust on my '01 3500 that will get repaired/replaced with new metal but I am curious to see what everyone on the site here is doing to prevent this vehicle eating monster from getting their truck. I have read that an oil based undercoating that is applied annually seems to work pretty well. It would have to be included in your maintenance program in the fall for winter preparation but has been pretty effective. There is also a DIY variant that could be done at home with used motor oil and diesel fuel mixed 50/50 and a hand pump sprayer. I have not tried this yet but I am giving it a lot of thought. I'd like to hear from others on the site to see what their rust preventative measures are. Not looking to start a debate about EPA approved this or that, just what works for you and no judgement on your regiment. Thanks
If I were back to work I'd throw out an offer. Been laid off for over a week now, hoping to get called back soon. I'll check back when I do to see if you still have it.
Oil change interval
I haven't seen any bio around here but I really haven't been looking for it either if that makes sense.
Oil change interval
Honestly with the Cummins I am not planning on oil additives just using synthetic. I was curious if anyone here had used it. I have been using 2 cycle oil in the fuel lately per some discussions on this site. I have noticed a bit of improvement with it in the tank.
