Doubletrouble
Staff
Everything posted by Doubletrouble
  1. I try to keep 2 stroke on hand at all times for chainsaws anyway, just have to keep more on hand now. I looked at Walmart the last time I was there. Their 2 stroke went up, it's now $26/gallon. I'll have to check at my local farm stores and see what they are charging. Also, I am not quiet familiar with some of the terms when it comes to diesel fuel content. What is the HFRR reference that I have seen on a few of the fuel threads? What does that stand for?
  2. So as the owner of a basically stock truck, with stock ecm and no tuner am I ok if say I take a trip somewhere and am stuck buying bio-diesel or bio-mass diesel? Assuming it's spring/summer temps out no additives other than 2 cycle oil for lubrication.
  3. When you are hooked up to a water source the TT has a bypass valve in order to just pressurize yor water system without filling the tank. As far as the toilet, they have a foot valve to flush them. Simple step on it and the trap door opens and water starts to flow to flush the contents down in the tank which is normally directly below the toilet.
  4. Your dash looks like mine just different color. Lol I'll pm you.
  5. I don't think I would try the liquid stuff. You certainly don't want any of that making its way into the fuel line. That would cause a lot of havock. Doesn't loctite make a thread sealer as well? Though I read about it somewhere while looking for something else.
  6. I was just curious if she was in the average range for what it is. As far as the abs sensors, I had a Chevy suburban that the abs light came on. Had to remover the sensor and clean the mating surface. It would get a bit of rust build up under there and increase the gap between the tone wheel and the p/u. I haven't checked for this on the Dodge yet. Honestly, it's been cold and I haven't felt like it. Lol
  7. Prayers to you and your loved ones.
  8. The speedometer works just fine. The light is an annoyance more than anything. Once it warms up I will address it. A buddy has an expensive snap-on scanner that does abs. I'll see if his will read the codes. If not I can just replace the sensors and see if that fixes it or take it to a dealer for scanning. Just don't like going to a dealer for much of anything. Very expensive just to plug into it.
  9. Yes it is winter blend diesel around here (northwest Ohio) so I imagine it would improve some in the summer. I also snapped a couple pics of the live data scanner while the truck was idling. I've attached them for y'all to look at. I'm new to diesel pick ups so let me know if you think something might be off. And yes, the abs light is on. It flashes constantly. Not sure why, my scanner won't link to the abs system. Brake light is only on when parking brake is set.
  10. I was just reading your write up on low pop pressure and how to recognize it. I have an obdII scanner with live data. I will plug it in next time I drive it and check the engine load at idle. Mine tends to idle a bit above 800 rpm so I am now wondering if it is due for injectors. If so, would it be better to go with a slightly bigger injector? Like a 50hp or 75hp?
  11. I have a 2001 3500 dually 4x4 quad cab long bed, stock tire size, nv4500 5 speed with 3:55 gears. What is the average fuel milage expected from these trucks? The only "mods" done that I know of are a FASS ddrp pump in factory location and the exhaust has been replaced but nothing crazy. I measured the tailpipe it's 4" but have not measured the rest under the truck yet. So to my knowledge it's pretty bone stock with 141k on the clock. Last I checked I was at about 15mpg. Mainly to and from work, about a 20 Mile drive, about 5 of that is considered city the rest is state route 60mph or highway about 65mph. Just curious if I'm around the norm for what I have. Thanks.
  12. On Jeeps they would act like that when the steering box broke loose from the frame but that wouldn't explain the fluid puking out. That's an odd thing going on there.
  13. I am curious of the syncros as well. I will be paying attention. My 3rd year syncro was out when I bought the truck. I have been double clutching 3rd to avoid grinding the gear down for now. I want to at some point replace all the syncros and do one of the 5th gear fixes to avoid that problem in the future. Possibly a clutch at the same time. I don't plan on a bunch of big power mods in the near future just don't want the trans to crap the bed while pulling our camper or something.
  14. A couple years ago we found a nice deal on an older jayco, 1989 but very well cared for and has the metal roof not the membrain stuff they use now and the underbelly is insulated and covered in metal as well. Some kinda of "all season" package upgrade of the time. We are very happy with it and have had absolutely no issues with it so far. The couple we bought it from were meticulous with it and made some upgrades of their own. A dormer fridge/freezer with a big inverter to run it while towing. Better Central stereo and speakers both inside and out. Can't wait to pull it with the dodge now. The 1999 k1500 suburban I used prior had it's hands full pulling it.
  15. OHH MY EYES! IM BLIND!!!!!
  16. I think more information would be helpful. Is your truck automatic or manual trans? Gear ratio, tire size and so on. It will help diagnose the issue. You should put this info in your signature for future reference. Makes things a bit easier.
  17. I meant to update this earlier but it slipped my mind. The wheel simulators are not stock. I could barely see a name where the center cap decal has been removed or lost. They are from Motoring accessories, I believe that is the manufacturer name. I was able to remove the crooked one and straighten it up an reinstall the cap. They just pry off, then the lug nuts have to be loosened or removed to resituat the big cover. Not a big deal. I am missing 2 of the fake lug nuts on the opposite side though, other than that they are all in good shape and my crooked wheel cover issue solved.
  18. Lights look great! Now I want some, see what y'all started!
  19. I have an '01 dually with the factory hitch setup on it. I am curious, what size pin did this take in the receiver originally? The hole on mine is egg shaped and larger than the 5/8" pin I normally use. I can take some pics if needed. I am probably going to have to buy a new shank already since this truck sits much higher than the suburban I used to pull the camper with. I'm hoping I don't need to replace the hitch right away as well. We don't usually go far with the camper maybe one or two trips a year no more than maybe 60 miles round trip. Eventually we will venture further but for now I just need to make it safe.
  20. Lights look great! Weather looks like it could be better. +1 on the fireball.
  21. I think I saw that post with a pic of the pattern. Looked pretty good.
