Everything posted by Doubletrouble
Truck is all over the place
I agree with drip, we all have our own flavor of bad luck sometimes
I would for sure drop the rear axle and inspect all the contact points, locating pins/holes, spring packs, spring eye bushings while your under there as well. When you reassemble be sure to use new u-bolts and torque to spec then retorque after about 100 miles or a week or so.
VP44 opinions
I will have to update my sig again. I tried linking it to my garage like some do here to give more detail but I can't figure it out. My truck is a 2001 3500 qcdrw SO with nv4500 5 speed
coronavirus protection
Myself and the wife will be staying home. I have a small errand to run tomorrow but that's it, back to the house!
It's reaching everyplace.
Spare tire winch
Not a bad idea there.
I saw that as well. It's getting very bad. I just told my adult children that they need to stay away. All 4 of them live near or in the city suburbs, I'm out in the country for a reason. Lol Unless it's an emergency stay home.
Spare tire winch
I may have to cut the length of the bolt down a bit. I had the tailgate off when I did the mod. The bolt rubs the bottom lip when I close it. Just need to figure out what to do with the spare now. Not gonna cut up the exhaust to make the spare fit. Guess it'll go back under the toolbox for now. Need to throw a bottle Jack and blocks in the box as well as sockets to change a flat if needed.
VP44 opinions
If it has been replace then I am somewhat relieved. That's an expense I didn't want to deal with anytime soon. Lol I have begun a 2cycle oil regiment when I fuel up to help prolong the life. I want to go to bigger lines with a pressure gauge before long as well to keep an eye on things.
Here in Ohio the number of cases, hospitalized and deaths have all doubled since Monday.
VP44 opinions
So @IBMobile, you think it could have possibly been replaced? I've been getting mixed opinions, it's not a huge deal either way. If it has been replaced I don't believe it was that long ago which tells me it will last that much longer is all. A VP is a pretty big expense so if it had been replaced it more of a piece of mind.
Spare tire winch
That's almost what I did. I put the head of the bolt in the end of the shaft and welded it the a nut on the end of the bolt and welded that so I could use a regular rachet/socket.
Spare tire winch
They're 85's then. I know they're the stock size for sure. The number of hand holes in the wheels kinda threw me a bit. Possible that it did not come with the wheel covers, they are for a 4 hole wheel. It is a basic work truck, I doubt the wheel covers were factory but I don't know. Did some searching. In '01 the 3500 wheels from the factory had 7 hand holes. The spare that came with the truck when I got it used is a 4 hole wheel. Someone just bought the wrong wheel simulators. They installed 4 hole simulators on the 7 hole wheels. Amazing how many people can't count.
Spare tire winch
Mine are the stock size 235/75/16
Spare tire winch
I was able to get it broke loose. Didn't take much effort really. Had it turning, cable going up and down just fine. Had a rachet strap out to secure once the tire was up. Placed the tire on the cable cradle and started cranking it up. The another problem presented itself. The spare hits the exhaust pipe where it goes up and over the rear axle. It's an aftermarket exhaust and large diameter than stock (4" I believe). So now that I have the winch working the tire won't fit up there. Just my luck I guess. On another note, I was doing a few things to the truck yesterday and noticed my spare is a 4 hole wheel. The six on the truck are 7 hole wheels. Any thoughts? I thought they were either 4 or 5 hand holes.
Spare tire winch
Most likely yes, I just didn't know the proper term. I will try to spray it down with PB blaster or something to see if I can get it to move.
VP44 opinions
I do need to do the ground mod, is it possible that could mess with radio reception as well? My factory radio seems to fade in and out sometimes like interference. With all that's going on right now I think I may have what I need for the ground mod. Trying to conserve money right now being I'm laid off again. Who knows how long this time. I also have a Buick rendezvous I have to replace all the brake lines on. Have the parts just dreading it severely. We're giving that to one of our daughters. Can't wait til it's gone!
VP44 opinions
That's where mine is now. In the future I want to relocate it to the frame.
VP44 opinions
Would the larger 1/2" line with a ddrp cause any issues?
VP44 opinions
Are there any tell take markings on an OE pump compared to a rebuild or replacement? Just curious.
Spare tire winch
Mine has a cap nut if that's the right term on the bottom. It's just a round cylinder with threads, bolt enters from above. Gonna be hard to get my big mits in there to loosen them. Lol
VP44 opinions
I do want to upgrade the system. I had posted before about going to 3/8" line and eliminating the banjo bolts for better flow and pressure. Probably replace the line from filter to VP first since I noticed a drip from the banjo on the bottom of the filter housing today. Gave it about an 1/8 of a turn to snug it up a bit. I'll check it again soon. I was just curious if that VP could have been replaced already since it looks newer than any other parts.
Spare tire winch
I'll try that. I was going to remove it but it look like the bolts come down from above. Not easily accessible. Maybe just spray the crap out if it and try to work it loose.
VP44 opinions
Truck has a bit over 142K on it now.
VP44 opinions
Not having trouble, just happened to take a closer look at the VP44 today and noticed that it looks like it may have been replaced. I say this because I know how aluminum will oxidize over time (truck is an '01) and this looks way better than I would expect for an almost 20 year old piece of aluminum to look. The fittings attached to the pump look fairly new also. Just wanted some other opinions so please see the 2 pics I took. It actually looks better in person.
