Doubletrouble
Staff
Everything posted by Doubletrouble
  1. I have a few vehicles in my past is love to have back! I think we all probably do
  2. Mine are disconnected at the moment. Wouldn't be the grids at this point.
  3. I looked at the batteries, they're dated 2014. 6 years old so it's probably about that time. As for the PCM, I haven't done it yet but I want to put a dedicated fuse online for that as well. Only bad thing about buying a used truck that's 19 years old. Alot if catching up to do on maintenance and preventative measures to avoid other serious problems.
  4. That's a good point, the batteries are getting old. The date sticker is still on them. I don't remember the year off hand though. Plus I've been wanting to get a battery load tester anyway. Nothing fancy but with all the tractors and other machinery around here it would be useful.
  5. So today I had to go to my parents house to do some work for them, had the truck loaded with the tools and materials I needed, noticed that I left my keys in the ignition. No big deal, I've done it before but, this time I left the ignition on some how. Started the truck, cranked just fine and fired right up. Volt meter was down a bit, comparable to as if the grids were on ( they're unhooked at the moment). Figured the batteries would charge on my 25 minute drive. I made it 1 mile and "check gauges" lit up, voltage now at 8. Checked the 150amp breaker, it was tripped. Reset the breaker, tripped again. Went back to the house and removed said breaker for now. Running late had to go. I don't know if I should reinstall the breaker now or not. Also, why would the alternator put out so many amps to trip it? Aren't the alternators (I assume mine is a stock unit) rated for 140amp output? Thanks for any thoughts. Btw, the breaker I am referring to is one I installed after doing the WT ground mod.
  6. I have to say I got really lucky on this one. It does have some rust but runs good with a fresh 305 v8, th400 trans and the famous 205 (I believe) cast iron transfer case. The trans need a new pump, she leaks real bad but I only gave $1200 for her so no complaints
  7. From the pics you can't tell it's been touched up. Everything looks uniform down the sides. She's looking real nice. Good work!
  8. GM has definitely lost their edge. To be honest the new GM trucks are ugly
  9. Oh, you noticed that huh? Lol Here ya go @dave110
  10. I'm going to need some of those to tow my RV. Are those OEM (guessing not by the price) what brand?
  11. Looking great!! What pads did you buy? I'm by far no body work guy that why I'm asking.
  12. As the title says, I received an unexpected package in the mail yesterday. A brand new set of headlights, complete plug and play with turn signal and new halogen bulbs installed. The wife though I went on a parts binge again so I was getting questions lol. I come to find out that a good friend of mine that had stopped over last weekend had noticed my terribly clouded and full of moisture headlights on my truck. He took it upon himself to order up a full set and have them shipped to me. They are basically stock replacements but I do greatly appreciate his generosity! Looking forward to getting them installed!
  13. It was nice that he took the time to show you what to do. Some shops try to keep their trade secrets to themselves. If you have the time a little tutorial with pics would be nice. Share with us a "how to".
  14. When he does, if it bothers him enough he can fix it. Lol
  15. Thanks for the link IBMoblie. I'll add that to the list. Heater core is now bypassed. Just used one of the existing heater hoses to do it. I'll replace them both when I do the repair.
  16. Wow, I had mine on my truck for 3 years with no trouble. Still worked when I sold it once I got my Dodge.
  17. Do the LED'S cut through the rain well? I've never had them (yet) so just wondering. The KC's I had on my Z71 cut through just about anything. Lol
  18. I had to use the heat today, been rainy and a little cool here lately and had to make a morning trip. Anyway, turned on the heat/defrost and found this after about 20 minutes of driving. 100% sure it's the heater core now so I guess I have some work ahead of me. I think I'll bypass it for now and begin collecting all the parts. I want to replace the heater core, a/c coil and do a good cleaning and replace the dash as well. So far everything seems to work as far as blend doors and such so is there anything else in there I should consider while I have it all apart?
  19. Ok, thanks. I was just wondering. I'll probably stick with the 2nd gen type when I buy them. Easy bolt on. Most likely they will be aftermarket, OEM cost way to much unless I find some on a salvage truck.
  20. Any rubber gaskets in the engine or trans will be toast, literally. VP44 will be junk as well. It would be a gamble at best I think. The engine/trans would both have to be rebuilt before use. As far as parting them out, I don't know about that either. If I were looking for parts I wouldn't want anything from a fire damaged truck. That's a lot of heat where heat shouldn't be. Just my $.02
  21. Just curious as to why one would choose 3rd or 4th gen mirrors over ones made for 2nd gen? Is there any advantages? I ask because I will at some point need to mount tow mirrors to my 2nd gen for towing our camper. The little Mickey mouse ears can't see around the RV.
