Haven't seen this for a while...
With that cute little trailer? That is a bit lower than I would have guessed.
I really hate to scale my trailer right now. I rather heavy. Not to mention I didn't shut down the engine much through the day and kept the A/C running between stops. But during unloading I did shut down the truck. I'm pretty sure I'm close to the weight of my RV weight.
I do.
That explains some of the miles per tank you get.
I only do once or twice a year for hunting or long backroad trips. I account for the fuel between the click and neck full on the next tank.
My truck quite often gets fueled and parked for a week or more and a tank full to the neck has nowhere to expand.
I have a tiny bit of seepage on the top of the tank...  I don't fill up into the neck unless I'm on a trip...
8mpg is pretty piss poor.  My 79 C30, 454, towing cam, Edlebrock intake, AFB, headers, huge truck mufflers, 3.73 axle, 16.5 tires...  got 11 mpg.  I thought 11 was bad.  Twin fireball 20g saddle tanks...  LOL!  Towing or empty, did not matter.  The AC mattered (when it had AC)..  subtract 1 mpg.
Edited by flagmanruss
My truck almost never sits for more than a day.
i don't top off that far. only let it click off 3 times. always get fuel from sams club unless traveling.
this trip i went from Flagpole az, to payson, to Phoenix, then back home i'm happy with the results. i dropped to 65 mph, and tried to keep boost under 10. edge set 4.post-1725-0-69691200-1438529958_thumb.jp
I am still on the same tank of diesel and will drive the truck again tomorrow. I'll peek and see where I am at.
IIRC the 2500 QCSB has a 34 gal tank vs the QCLB 35 gal tank?
With you topping off I would guess you have a gallon or two more than I do with the bigger tank and only filling to the click.
The 1st "mod" I ever did to my truck was the "fuel tank vent mod".   When I first got my '04.5, it would take 27-28 gallons of diesel to "fill her up".
After the "fuel tank vent mod";  when I fill up now, MightyWhitey takes 30-32 gallons.  I think I have the "little" tank.
