XRF Balljoints
Dave 110, this is a great offer, Just beware if Mike gets the torch. He as been known to strike a man in the cahones with a super heat ball stud in the past. :tongue:
Ha Ha. I can pretty much guarantee the torch will be deployed. Nothing beats the old gas wrench if used correctly.
attachicon.gifReplacing_Ball_Joints.pdf
Here is a right up I stumbled across a little while back. i did not have the benefit of any pneumatic tools when I did mine. Still managed to do it however.
It is basically bolt off bolt on except that everything is pretty well stuck. So be prepared for some frustration.
Thanks for that. I believe I saw it before but my 99 is opposite from this. Same idea though.
I never use a fork for taking steering components apart, one usually does more damage than not with them. Just wrap on the housings with a good hammer several times and they more often than not break loose that way alone.
i have one and use it when I know the part I am removing will not be reused. I have also had some luck with the wrapping method at times. Did not work well on the unit bearing however. Not sure I had a big enough wrapper for that.
Edited by dripley
