Random ABS light and weird braking performance
- Replies 57
- Views 11.2k
Mopar1973Man 25 posts
dripley 5 posts
CTcummins24V 5 posts
Hawkez 4 posts
Wonderful news. (MoparMom and Module Master Staff) I had a nice little chat with the crew at Module Master in Moscow, ID. I did find out that Module Master does quite a bit. ABS module
Well we will have to keep an eye on this, you might have found a valuable resource. When I first saw the picture I thought she had the results of your pregnancy test. They both look so happy.
Rebuilding the alternator is extremely easy. It just the diode pack is expensive from LarryB. http://www.fostertruck.com/catalogsearch/result/?q=alternator He supplies the bearings, pulley,
Let me say yesterday I got a good scare. Travelled up to McCall, ID to do my usual shopping. I normally take the back road around McCall to the store. When I started to approach the light I was easing into the brakes and all of a sudden the ABS is back pumping me not allowing to even stop. I was saying my prayers before I rear ended the car ahead of me. Then at the last 5 MPH of coasting the ABS tripped the light and brakes hit NOW. Missed the car ahead of me by inches. Now let me say I've replace all 3 speed sensors and been seeing the random light now and then. I've even tried with no shims in the front and now back to 1 and 1 in the front and the lights stay out for the most part. Now if you just lay on the brake hard like a panic stop now I get a wild jerk to the right. Quite spooky driving. Some times you can stab the brake and get the rear axle to lock one side or the other and not trip the ABS light. Really strange behavior...
So I better go check my AC noise. Guess what the alternator is at .07 AC volts. The alternator is done. So my weird random issues was a alternator problem. Now lets hope It's not fried the ABS computer. I guess Friday I'll be getting another alternator.
