HO VP44 or SO?
I found this on Cummins Hub. It lists 2 hp ratings for 1999. 215, auto and 235, manual. does not call it an HO but there must be some difference. There is more hp and torque difference in 99 than 02. http://cumminshub.com/timeline.html
You just want to be sure your core is the same as the one you get. I seem any places that want except and HO for an SO and vica versa for a core.
The 1999 SO trucks came with the optional 5600, and the tranny came with the smaller 1 1/4" input shaft like the 4500.  To be sure if you have the SO or the HO, you can confirm with the VIN.  If the 8th digit is a 6 then its an SO.  If its a 7 then you have an HO.
  • Like 4
Thanks KATOOM, the 8th digit is a 6.  So, it looks like I was able to verify a couple different places that this is a SO....now I am just waiting for the pump to come in along with the other fittings and pieces that I am going to install.  After I can get it running I'll verify the alternator and maybe this time next week I'll be waiting for parts to rebuild that.
On 2/25/2016 at 9:40 PM, Me78569 said:
Dont worry you are fine no 215 pumps are out there anymore, at least new.
The SO will work perfect for you.
Just to muddy the water back up again... :stirthepot:
Most all high-performance pumps are typically built from a SO pump. So most folk typically migrate to the SO even from the HO pumps.
The thing that bugs me is every where I looked you have to return the same pump for a core that you buy. So if I wanted to put an SO on mine i would have to find an SO to return. Always thought that was a little strange.
