- Replies 16
- Views 5.8k
Mopar1973Man 5 posts
dripley 2 posts
joecool911 2 posts
notlimah 2 posts
Usually when I get my parking brakes installed and adjusted properly I drive at slow speed and apply parking brake few times on and off just to get them seated in the place than after few times doing
I adjust mine so it doesn't drag and bites well without excessive pedal throw. Not scientific.
Parking brake should be able to hold the vehicle from rolling on a mild slope. Now with a trailer it may or may not still hold as well but it does help to have it properly adjusted. Basically adjust y
Finally after all these years I wore out the parking brake shoes and the rear cables are hanging up which doesn't help either. So I pull the driver side apart to look things over and see if I could free the cable up. That was fairly easy just tape a funnel to the cable end and pour a bit of diesel fuel in the funnel and push and pull the cable. This freed the cable up again for now. Closer inspection I wore on shoe down to the steel and just about to make steel to steel contact with the drum. So for about $90 buck I'm getting two new rear cables and set of parking brake shoes for the truck. Explains why the truck would creep off on me. I should have parts by tomorrow...
