- Replies 33
- Views 5.5k
leathermaneod 14 posts
TFaoro 5 posts
Mopar1973Man 4 posts
IBMobile 3 posts
You can download a holset manual for your turbo and it will guide you through the rebuild. My kit didn't come with the turbo to down pipe adapter gasket and mine was in 3 pieces so had to get that sep
If the compressor wheel touches the housing then the bushings/bearings are worn and that translates into excessive radial movement and the turbo needs to be rebuilt. Some rebuilders deem the core non
I'm following along with the HX35/40 turbo that @CSM gave me. So far after disassembly of the compressor housing I can test the compressor wheel is nearly making contact with the housing. Enough the t
Hey all,
So based on the pics Im pretty sure I need to rebuild my turbo sometimes before too long. I had a thread on here about it before, but decided it wasnt as urgent as I thought. I thought any shaft play at all was bad, and thanks to you all I learned that is not the case. Anyway, I changed my oil today and I was wondering what you all think of these pics. It doesnt seem to rub at all when I spin it by hand and even when I push it to the side and try to get it to, but in the lower left there are a couple spots that look like they could have touched....by the way I didnt mess with it too much because I've heard its very bad to spin a turbo without oil circulating through it. Yes I know the blades are knicked and I need a new comp wheel. Thats one of the big reasons I haven't rebuilt it yet.
