two stroke oil question
13 minutes ago, Mopar1973Man said:
1989 to 2002 you run 128:1 ratio or 1 ounce per gallon of fuel pumped in the tank.
2003 and up you run 200:1 ratio or roughly 1 ounce of oil for every 2 gallons of fuel.
I got my buddy to switch over to 2 stroke on his 06 Dmax. He used to get a low fuel rail pressure light at WOT (Has egr blocker, exhaust, intake, built trans, and EFI by Idaho Rob). Now with the 2 stroke, he gets no light and the truck seems to run better. He does 1oz per gallon and it seems to work for him. Truck is at 253K and still sounds good!
  • 3 weeks later...
On 7/16/2016 at 5:01 AM, CUMMINSDIESELPWR said:
so i was at wally world and looked at the supertech 2 stroke oil as the jug seemed different. i read on the back and front and i couldnt find where it said it was ashless as ive read before.
did they change something or is it still good to use? what other ashless 2 stroke oils are available?
I just bought ea few gallons and on the back at the top it says ashless.
