1 hour ago, trreed said:
They should.  have you set up your drivetrain info under settings?
Yes, and it shows gears...just not the gears im usually in.
I will make mentioned changes and see where we are at.  Raising the scaling will lesson the effect/ramp up of the wiretap fueling yeah?
Boost scaling is the point at which the wiretap hits 100% at this set boost pressure. So if you set for 20 PSI the wiretap is 100% by the time you hit 20 PSI. So yes... raising the boost scaling is going to lessen the ramp up to the max wiretap.
so in your above tune you will not get %100 wiretap until 35 psi.  10 psi is where the map starts, and it rams up to full wiretap in the next 25 psi ( boost scaling)
20 minutes ago, notlimah said:
We can compare 0-60 times
That's feasible... At least for 0 to 60 times you can do that legally. Hmmm... Don't give me bad ideas... Special members area. Oh! Slap me before I do something stupid...
Anyone have any tunes for a 7x.010 and a he351cw i just updated my adrenaline from to the v2 platform and recived my bluetooth adapter yesterday , i only played with it for a hour last night but i couldnt get a tune to load i have a samsung galaxy s8+ thanks advance
2002 24v 242k on the body brand new engine with 300 miles on it !
That's the same setup @Me78569 runs. Here's a link to his daily tune
With the Samsung devices, it seems you have to email it to a gmail account and then open/import it on your samsung from there. At least that's what's worked for me.
Posted (edited)
Awsome! What do i want to select for my model theres like 3 different options
Edited by MoparLevi
Anybody have a good daily tune with 125 Injectors I can use as a base setting? Just updated my iquad to V2 and going to try a few tunes this weekend.
