Fuel Canister Drain Valve
Hey guys just wondering if the drain valve is rebuildable?  Mine is leaking out the top. I did notice that the top cover was loose and tightening it helped a little but it still leaks. Can I just get some o rings for it?
Thanks in advance
d
The filter canister filter should come with a new o ring for the canister. You might take a look in the parts look up tool here and see whats there. If it has o rings it cant that hard to replace them I would not think. But I have never had a problem with mine to know for sure.
