I got a turbo from @CSM and I went ahead and got it pulled down to rebuild it. While its apart I figure I would measure out the turbine and compressor wheels. Here is what I got.
Compressor
Inducer 60mm
Exducer 83mm
Turbine
Exducer 60mm
Inducer 69mm
From what I found online this is a HX40 compressor wheel. The HX35W is 56mm compressor wheel. So this should be a rather nice boost (pun intended). Waiting for my bearing kit to come.
  • Replies 81
  • Views 25.1k
  • Yep, sounds like a HX35/40 hybrid with a 8 blade compressor.   Me thinks Mopar1973Man has caught the the power bug...
  • So fun fact of the day, there are two different versions of the HX35.  The 8 blade HX35's were 56 mm.  Then, Cummins quietly switched to a 7 blade version that's actually a 54 mm inducer.  I found thi
  • Mike was talking about checking his stock turbah, that's where my comment originally meant to apply.
It has a nice whine as well.  Kinda high pitched and way different than my current Borg Warner.
I am really curious to see what your temps do and how the quad tuning changes from a stock turbo!
:whistle::think:
Naw... +75 injectors and HX35/40 turbo power bug? I don't think so. I've already got enough power to get in trouble and break expensive parts like transmissions with my previous setup. Come on brown truck get here... I need my parts. The injectors are all pulled out and head is ready for injectors. The turbo is tore down and ready to be rebuilt.
Oh, it always starts small...  1/4 turn of the smoke screw here, slide the plate 1/16" forward there...
Though I should talk, I've got "120hp injectors" and am STILL running the stock turbo. haha
Since CSM gave me the turbo I figured since I needed new injectors I called Jacob @ Diesel Auto Power and talked him about injector replacement and bearing kit. Talking to him we figured we would give the +75HP a go with the HX35/40 turbo. Being I came from +50 HP injectors small boost in power but also adding the turbo. Then with the fuel management of the Quadzilla I should be able to create good clean power. We will see.
Should be a good setup for you. It's very similar in size to a HE351, but those are 7 blade like a Super 40 wheel.
What is the turbine housing size?
It looks like you have the turbine wheel inducer/exducer labeled backwords.
Should be able to make them run clean as a whistle no problem :thumbup2:
Should also be interesting to see what difference altitude makes. I know you do some long climbs, so I would expect it to be a touch smokier at elevation with the same tune. We'll see.
Oh and none of this actually happens without pictures!
At low to mid throttle or low rpms it runs the potential to run hotter and smokier the higher in elevation one gets, especially in summer. (Think density altitude vs actual altitude).
Pics are certainly needed!!!
Can someone explain a little better this hybrid thing. So on the outside you can not tell the difference, still says hx35 on it? And what exactly do you need to make it a hybrid which piece goes where? I've always wondered if mine wasn't the hybrid, few guys that rode in my truck thought that it has more power than it should. One has a Ford another drives a Chevy and I got a Dodge what do you know.....
Edited by Dieselfuture
Just did a quick search and found Turbo Lab America,  https://www.amazon.com/gp/aw/d/B00M9NJIOU/ref=cm_cr_arp_mb_bdcrb_top?ie=UTF8
They say hx35 housing needs machining and also
"This is a HX40 Compressor Wheel and Housing with a 60mm by 86mm Billet Extended Tip Compressor Wheel. This is an Excellent HX35 HX40 Hybrid Kit also! Details: *Compressor Wheel is Balanced and Ready to Install *Light Weight and Aerodynamic *Designed for Faster Spooling *Outflows Stock Wheel by 5 to 10 % NOTE: The Bearing Housing Must Be Machined to 87.5mm for the Compressor Wheel to Install. We offer this Service for $20, but You can have this Done at a Local Machine Shop Also!"
It should take a bit more heat to light, but after it is lit it should be a tad bit more powerful at a given HP level.  The only real driving difference with it compared to a stock turbo was that the hybrid is easy to bark.
Edited by CSM
Using a HX40 compressor on a HX35 turbine.
Shoulda added the super hx40 76/64 turbine to that. :whistle:
Any surging? I did the 60mm upgrade to a WH1C w/14cm non gated exhaust housing and it surged like crazy with heavy throttle. Surged w/12cm gated too.
I never had any surging issues.  The cruise control on automatic trucks is never happy with non stock fueling, but that's a different issue.
So fun fact of the day, there are two different versions of the HX35.  The 8 blade HX35's were 56 mm.  Then, Cummins quietly switched to a 7 blade version that's actually a 54 mm inducer.  I found this out the hard way when I was rebuilding my HX35 and needed a new wheel...
Edited by trreed
I'll put money down that it's a 54 mm inducer, as all 24 valves that i have seen have the 7 blade version.  Ironically, it seems as though the 7 blade flows more air than the 8 blade despite its smaller size.
Edited by trreed
