Exhaust Brakes and head gaskets
Eb are not hard on headgaskets assuming you are not injecting fuel when using one going down the road.  The eb is just creating a pumping loss in the engine.
There is far less cylinder pressure being created compared to an actual power stroke of the engine
  • Like 3
And just to clarify, on vp trucks it's not necessary to upgrade valve spring like with the 12 valves? At least that's what I was told.
Correct. 12V motors came with weaker springs and have a larger surface area per valve.
By blocking the exit of air from the engine you force the engine to compress pressurized air during hte exhaust stroke rather than allowing that air to exit .
This creates a large pumping loose in the engine and then you have an engine brake.
