- Replies 22
- Views 7.9k
Mopar1973Man 7 posts
Dieselfuture 3 posts
Wild and Free 2 posts
CSM 2 posts
We do not offer a ceramic single disc clutch for this very reason. They will hold some power but will groove the castings fast and not last very long. Peter
I buddy ran a cheap single ceramic he got off ebay for a while. When I pulled it out, it also had a 13" dual drilled flywheel with HD pilot bearing. So it's not necessarily from SB or Valair.
When my first gen wore the oe clutch at 150,000 I took it to the guys that been around for a long time. When I asked about replacing it with a ceramic clutch they looked at each other and went on conv
I just got a 1999 Dodge Cummins in the shop with a clutch issue. I got it pulled out today and this truck has a single disc ceramic clutch. The clutch has completely eaten a deep groove approximately 1/16" to nearly a 1/8" in the pressure plate and about 0.010 groove in the flywheel. Surprising there was zero hotspots in either face. The friction plate was still in good shape but it completely ruined the pressure plate and flywheel will need to be turned. This truck is stock for the most part other than Edge Juice tuner. So for those of you considering ceramic clutch I wouldn't advise it. As this happens to be the second ceramic clutch that the previous owner installed and neither of them last very long well the friction disc did but even the previous ate the flywheel.
