If your are going to keep using the oem air box its good to shave the lip on the lower box just a little. It helps the upper section seal better/ tighter to the stock filter rubber seal.
2 hours ago, trreed said:
Is that were you cut holes in the sides of the bottom part of the air box?
People would do something similar in the 6.5TD community.  I never did it when I had mine.  They called it "Swiss cheesing" the air box.
