- Replies 125
- Views 62.2k
Me78569 42 posts
notlimah 14 posts
Quadzilla Power 13 posts
Matthewski89 11 posts
I've got to upload my Edge Comp look a like tune. I'm pleased with the performance and MPG is nearly the same as my old Edge Comp.
https://mopar1973man.com/files/category/22-quadzilla-standard-tunes/
I dont know. I validated both tunes and they are the same. They both load for me as well. Confused.
Android
Some devices don't allow the link of the quad app to the .json file type of the tune. You can still import manually.
1. Open the quad app
2. go into your custom tune menu
3. click Import in the upper right.
4. next a file explorer will open. Each phone is a bit different, but you want to click the settings in the upper right, then "show internal storage"
5. You will now see this structure.
6. you can navigate to the downloads folder and click the tune you want.
IOS
Also, regarding loading a tune on iOS. The easiest way that we have been able to do it is to mail the tune to ourselves. When we opened it on iPhone 4 mail app and then open the attachment we see this:
Click on the highlighted icon to open up the sharing button. It will load up options of programs to share to. Like this:
When you see that, simply choose the Open in iQuad option and you should be good to go.
Update for the iPhone implements a twirly when loading tunes or saving parameters. It will also give the option to reset to defaults if loading tune parameters fail. (i.e. when trying to load a V2 tune to a Legacy tuned Adrenaline it will fail a lot).
Edited by Me78569
