Posted (edited)
Where did you buy your 40amp water proof relay ?
Walmart? Specialty Electronics store?
Edited by GSP7
I ordered mine off of amazon. They are cheap, but I have not had any issues with them. 1 relay for $10 or 5 for $25.
Weatherproof Relays
Posted (edited)
Thanks Red Rambler
I was digging in my trailer hitch plug wires
I see the red/org is a heavy gauge...Found the purple/bll also
There is a large gauge light blue... it is trailer brake
So I think I have it figured out for my back up light. Now i just have to decide on a light.
I think Im just going to get a 35w or 55w holagen , like a  4 1/2 Hella or small sealed beam instead of the Led stuff.
I got a feeling the inexpensive led small 36 watt light bars etc are only going to last a year or two and burn out or rot away from the elements and water
I also have a second trailer plug the original owner installed inside the bed for a  Cab over camper or fifth wheel plug in. They tapped into all the bumper plug wires but they used completely different wire colors(stupid idiots)
Like the B+ Red/Org they hooked a black wire
Grn/brn has a large guage red wire tapped into it,,,
Blk/org has a green wire tap
Blk has a white wire tap
Edited by GSP7
Posted (edited)
17 minutes ago, GSP7 said:
Thanks Red Rambler
Glad you got that figured out and I concur with you on the light bars. My expectations are a year, year and a 1/2 max, given the harsh conditions they must live in. I have attempted to conceal mine as much as possible. Below is the exact light I purchased for $29. If it lasts 1.5 year I would would be happy.
Edited by Red Rambler
My old 81 chevy K20 4x4 has a old metel housing 4 1/2", 35 watt sealed beam back up light tucked back up under the rear bumper.
Its been on the truck 30 years and the light its self is probably from '60s
Still works great , and I can get a new bulb or it if needed
I just ran across this vid
Inexpensive vs mucho $$ LED
Nice video. Like anything else, you get what you pay for quality wise and lighting is no different. The huge price variance is a big factor that is for certain. Those Rigid lights are nice!
Posted (edited)
Kind of like my finding with PIAA RF 530 Series LED's.
http://www.piaa.com/store/p/147-LP-530-Driving-LED-Light-Kit.aspx
When PIAA LED driving lights are brighter than Morimoto D2S HID's That says something about the quality.
Hey moparman mike,
Are your back up lights on your rear axle just the Grote 64931 Rubber tractor/utility lights 35watt that you installed 100w bulbs into ?
What about your old front ones that you replaced with the PIAAs/ same thing, rubber Grote housings?
10 minutes ago, GSP7 said:
Hey moparman mike,
2
Yeah, just rubber tractor light buckets. I got mine from NAPA years ago. Yeah, the fronts were 100w bulbs as well and ran with two relays. One relay controlled power off and on. Then the second relay was controlling hi and lo beams. 2 bulbs where aimed hi for hi beam position and the other 2 bulbs where aimed lo for my lo beam position. Now as for bulb life for the old 100w bulbs the last batch was in the range of 9 months to 1.5 years.
Backup lights automatic to come on with the transmission shifted in Reverse or I had a switch that I could toggle the reverse lights for rear lighting, for example, hitching up a trailer in the dark. Lowering the spare tire in the dark. Lots of good uses for my rear axle lighting with a toggle switch. The rear axle light lasted a long long time being they are rarely turn on for very long.
Posted (edited)
Cool !
Im looking at bulbs ,https://www.1000bulbs.com/category/par36-sealed-beam-flood-lamps/
I have one 35w on my old chevy
Im looking at the 50w flood  to swap out for rear lights
Not sure what these Halco Haloxen's are looks like alittle brighter and longer lasting.. Flood or spot beam
https://www.1000bulbs.com/category/par36-halogen-xenon-reflector-flood-lights/
Edited by GSP7
Where is a good place to splice in the "toggle by pass switch" for the rear back up lights?
Is the only place to slice in,, right at the reverse switch on the transmission or is there a better closer place ?
I finally got my light bar mounted and hooked up. The cold today is brutal and trying to work without my hands going numb from the cold but I can't work with gloves on, gloves make it impossible to use hand tools for the most part. I am happy with the end results, given this is a cheap light bar and the sole purpose is to backup in my driveway.
Posted (edited)
Looks like it works pretty good.  Did you use the brackets that came with it? . I wonder how you attached it under there?
I just received a couple lights in the mail today, but Rock Auto lost my other previous order for my neutral/back up switch, and rear abs speed sensor. Post office says they created a shipping label but never shipped the package.
Edited by GSP7
Posted (edited)
I used square U bolts that fit over my receiver and made longer brackets to attach to my aluminum bracket. I tucked it up as high as possible. I used rubber spacers in between my brackets to reduce any vibration.
This is from my '01 FSM, so wire color may be wrong, but there should be a factory wire already at the rear for backup lights.  In this schematic, it is the violet black (vt/bk) wire.  This goes into the factory seven pin trailer connection.
HTH,
Hag
2001 FSM Ram 8W-54-3.pdf
(1st post in this thread)  couple years ago I put light bar connected to hitch.  I KO'd it shortly later crawling into bed with my big foot.  Much better design in pics above with light being protected by something.
Going to get another light someday but going to mount under somehow.  Thought I found a light at junk store that vibration wouldn't ever be a problem.  Light had a CAT number on it.  Looked it up online and found out it was 24 volt, so I passed.
52 minutes ago, GSP7 said:
Yes, I sure did. That looks just like it as well.
The way I mounted mine it has a round rubber cushion that is between the light bar and the mounts. So vibrations should be limited, other than typical road bumps that shakes the whole truck. The green arrow below is pointing to the rubber cushion.
