Titanium 150 Pressure Adjustment
I’d leave it. It’ll settle out over time and filters will clog a bit and bring that number down as well. Only spring I’ve found that’s put an actual psi associated with it is from Vulcan and it’s a 17psi Airdog spring but it’ll work in your FASS. So you could do that if you wanted. I went that route but only because I was having all sorts of issues with the FASS springs. Psi when I first installed was 18.5 idle 17 at WOT. Now I’m 17 idle 15.5 WOT.
Is that a used Fass you got from someone else? Did they stretch the spring or something?
20 psi is higher than Fass sets them and tests them at is what they told me
Edited by GSP7
Sounds like you’ve got he cats meow formpressures.
Yea can't complain. I didn't mind it before but at least it's still within the limits. I am going to be changing filters here soon and also routing my fuel lines back through the stock fuel basket to get the extra filtration so we'll see what pressures look like after that, I don't expect much change.
7 hours ago, tylertrebilcock said:
those sound like decent numbers 20 is about as high as you can go with the vp. you could try removing the spring and clipping off a coil or two
If I’m going to do that I’m gonna get the whole new spring so I don’t risk getting the truck grounded if I mess the spring up lol.
I’ll be changing all 3 of
my filters as well today....
Why didn't you just get them with pump, or just in case.
@notlimah what filters are you planning on using Fass or something else. Here is a Fass site with filter cross reference, https://www.fassride.com/portfolio-item/replacement-filters/
I just got this one from Dap.
  • Donaldson P551313 (3M)
, Fass says it's okay to use, but it only flows haunted GPH, I'm not entirely sure how many GPH Fass filters flow. Someone has to make it for them, and I heard rumors that it is Donaldson that does.
What do you mean? My Fass did come with filters. Im switching them for new being they have 20k on them....
Wow you already put20k on them, do not know that. Even then I still don't believe in changing filters until I start seeing PSI drop
No no i didn’t even put 1k on them lol. I bought it used and he had the 20k on hem lol. My Fass sounds like a rock tumbler and supposedly new filters will make it run smooth like it should haha.
Why would you want lower pressures?
20 is not the max pressure for a VP.
@notlimah - it has the Vulcan airdog spring with the end coil curled to keep the ball from sinking into the spring.  Hasn't changed pressures from when it was set over a year ago.
I’ll be using Donaldson filters as well.
Ah, that’d explain why he’s seeing a little higher then me. I might do the same to my spring when I get things apart for this filter change.
