Center Console/Armrest
So I have a spare set of seats and Console/Armrest.  I don't want to change the whole seat portion, am hoping I can just pull the armrest/console off and swap them.  DOes anyone know if the two big phillips screws where the armrest pivots will allow me to just pop that piece out and switch them?
12 hours ago, Mopar1973Man said:
Actually its easier to just remove the center seat from the other two. Just 4 bolts and the entire center seat comes out.
This is exactly what I did.  Enabled me to get in there with compressed air and the vacuum and clean it all out too.
Two bolts are a 'drop-in' ....
Two need to be re-drilled ...... 10 minute job.
Console has a 12v utility socket, another for a computer, and the under seat compartment is made for a mobile radio.
Easiest up-grade you'll ever do.
Do you have pics a little further out? I’d like to see how it goes with the seats and dash!
Not the best shots Mike .... hope this helps.
Mine aren't hooked up. Will be adding a mobile radio soon.
The console has the wiring harness .... the truck doesn't.
Edited by Macarena Man
add more info, thanks,
Dang only one port. I'm in the process of looking at re-doing my accessories in the cab. Right now I need 3 USB ports 2 Amp minimum. Basically 2 cellphones and I want to change up my Garmin from a cigarette lighter charger to a Mini-B USB cord. I've been looking into 12V USB port and solutions.
  • 3 months later...
  • 2 months later...
