Hey guys, finally got my stealth plate installed and got everything buttoned back up to go for a spin and had the cel come on throwin the P0122 for low voltage. I read through the troubleshooting briefly but was wondering if there was anything quick I should check since I just had the apps unhooked to install the stealth plate?
4 hours ago, dripley said:
If everything working right just clear it and see if it comes back
:iagree:  When I changed my injectors I had both the APPs and VP unplugged.  When I started the engine the CEL light was on coding for the APPs and VP.  I cleared the codes and then life was good.  The only thing I can think of is I turned the ignition on with these things unplugged.
If it comes back then do the diagnostics.
Yea I had to turn the ignition on with it unhooked so I’m wondering if that’s all it is. I also didn’t recalibrate the apps after having the batteries unhooked so I may just leave the batteries unhooked for a while, recalibrate and see if it comes back.
12 minutes ago, trreed said:
Good plan on the relearn tho.
Not a good sign though. If you have to do relearns of the APPS sensor all the time to gain a stable system that is a sign of AC noise issue on the ECM
I’d agree with you Mike if this had been happening before and/or I hadn’t just had the APPS disconnected and hooking/unhooking the batteries with it unplugged.
I just reset the codes, unhooked batteries, let sit for an hour or so. Hooked batteries back up, reset APPS. No codes, drove fine.
