1948 Dodge COE Build
- Replies 25
- Views 15.3k
Dodge48 12 posts
dave110 2 posts
PilotHouse2500 2 posts
Timd32 2 posts
Bacon Creek, can't help you there; I'd contact American Wheel, I'm sure they could answer any questions. Thanks again for your interest in my "project". Part 7: As some of you probably n
Part 3: The pictures below reflect the bare chassis that still has the "outriggers' that supported the extended floors and the long overhang behind the rear axel. I borrowed the neighbors plasma cut
NIaacs and JAG1, thanks for your interest and comments. NIaacs, the front axel is an F50 rated at 5000 lbs, you're right, it is simply a heavier version of the M300 axel. The differential is a Spice
These pictures reflect My "project" as I bought it. As you can see it has a 440/727 engine/transmission combination. In addition it is on a 1978 Dodge M300 MH chassis with 17.5 inch wheels. My intent on buying this was to restore it as a "truck", I'm not into the "slamming school", though I respect the right of others to pursue their vision; there are just too few of these particular trucks to deny them there place in history. Having said that, I always do what I call a performance upgrade to most of my projects; in this case I have opted to replace the 440/727 with a 1996 5.9BT low miles diesel and a 47re transmission. Following submissions will include the "teardown" of what became my chassis, then the "fitment" challenges (of which there were/are many). I do need some help in one area (that I know of), I badly need a 2WD wiring harness, my intent is to use a 96-98 wiring harness which accommodates the 47RE 2WD transmission. More to follow.
Part 2: As I mentioned previously I wanted to build a truck, the smaller M300 Dodge MH chassis was too small for my objective. I had seen a 32 foot Executive MH in a local wrecking yard that was built on a 1977 Dodge M500 MH chassis with 19.5 inch wheels which I picked up for $800.00 delivered (so now I have two 440/727 units), also got a low hours Onan 6.5 kw generator which runs great. These pictures reflect a couple of the steps in demolition, my only concern was not to do damage to the chassis/suspension. I say to those of you who motorhome; I hope yours is better built than this one was.
Edited by Dodge48
Starting over with better clarification.
