- Replies 22
- Views 4.9k
Manimalmother 8 posts
Dieselfuture 4 posts
dave110 3 posts
Marcus2000monster 2 posts
Here you go
I was going to say, if the light is coming on then vacuum is pulling the vacuum actuator far enough to trip the light sensor but if vacuum is weak maybe it's not engaging all the way. If you put
You can just put front end on jacks and put a hose on actuator and start (no dirty thinking) sucking and see if it engages by turning driver side tire. Then put that piece of tube on the other line/fi
Folks it seems like as soon as I fix one thing another one breaks!
I am having 4x4 issues with my truck. When shifted into 4-high or 4-low the 4x4 light comes on on the dash but the front axle is not engaged.
The transfer case obviously shifts into 4-low so I pretty much have a 2-low scenario.
I started checking vacuum lines but my HVAC and cruise work fine.
The 2 lines that come up from near the transmission are what confuses me. One of them ties into the main vacuum line on the cowl. The other has a 90 on it but is not connected to anything, and I can't seem to find what it would look to. According to the vacuum diagram this may be the TC vent?
Any help would be appreciated.
Thanks!
