- Replies 28
- Views 6.5k
I sleep 2 ways. One, on the cold side of the AC unit or Two, on the warm side of the heater. The rest is up to your imagination.
My situation is a bit different with an all fiberglass camper, there are no seams except where the aluminum framed vents are screwed to the roof. A total of 4 vents, the factory used a coating called
How do you know its needs replacing, big rips or black showing thru? My 03 motorhome looked shot with black showing. Ran across the old CruiseAmerica parts manager in our RV travels. He told me wha
I need to replace the roof on my 5er and plan on doing it myself with help from friends. The local RV shops around here want $5k to start "and it could go up from there". Right now it has an EPDM rubber roof; so has anyone replaced theirs, what did you use, and how hard was it todo?
