- Replies 25
- Views 8.2k
wil440 9 posts
Evan 6 posts
dieseled 3 posts
Silverdodge 2 posts
Wil, Keep looking. The diesel 2500 rams with manual transmissions got the Dana 80, which would be your single rear wheel 3500. The automatics got the Dana 70u, which is still not a terr
I put a dana 80 dually rear axle complete from a 1996 3500 on my 99 2500 , the 99 had a dana 70u so the pinion yoke is about 1" closer to the t-case , driveshaft may or may not need to be shortened 1"
Ohhhh I like your style . Very sharp looking truck
I have a complete 5.9V8 3500 4x4 sat getting rougher by the day, is there any information on here about fitting the rear axle and springs to my 2500 4x4, same year just 2500 is diesel.... 3500 is petrol would the springs be too stiff ?
3500 has snowplough option from the factory, I'm assuming this is front springs but is the front springs on the diesel stiffer ??
Is it easy to use both axles ? does the dually bit unbolt IE the extensions on the front and the wider deal on the back ? will the bigger rear brakes be too much for a 2500
I'm thinking about parting the 3500 so would keep all sheet metal except maybe the bed
so would keep
maybe engine and trans maybe for a job rated I fancy doing if the 47re can be made to work without the trans ecm and use a smallblock intake and carb and ignition
transfer case for the 2500 if it's the same
both axles again for the 2500
but the question is more rear axle and springs, I did a search but there 300 odd pages
