- Replies 26
- Views 13.1k
NIsaacs 9 posts
Mopar1973Man 6 posts
dieselautopower 4 posts
Me78569 3 posts
The compressor dimensions are only part of the story. There is tip height that is not included in many measurements. In short the S200GXE is newer development and it was recently adapted to fit
kinda like saying a 2L engine from 2000 should make the same hp as a 2L engine from 2020. Newer technology and design allows for higher output with the same size. t
Looks great! For heavy pulling on what appear to be stock head bolts I’d set it around 33-35 and see what you get for EGT’s on grades. What where you making with the stock turbo?
It was a direct bolt in like advertised for a stock truck with a direct mount exhaust brake. I did need to clock both housings and move the exhaust pipe back 3/4". I did a quick 1/2 mile shake down run to check for boost/exhaust leaks, all is well. The boost is preset at 26 psi, it was exact. What should I set it at, for 400hp? It dynos 400hp with RV injectors and the Edge Juice. They advertise 450 hp @ 40 psi.
I will get a rebuild kit for the oem HX35W (340k miles) and save it for my '91. It has the stock HIC with a #16 turbine housing. It also has the direct mount exhaust brake.
Edited by NIsaacs
