2006 Dodge 3500 - Installing Valair (quiet) dual disc clutch
- Replies 19
- Views 6.1k
AH64ID 8 posts
Mopar1973Man 6 posts
Dieselfuture 3 posts
Threadzy 1 post
Allegedly Cummins spec’d the pump, not FCA. Cummins was trying to avoid an external EGR so they used a non-reentrant piston deign. That piston has a very shallow bowl and thin lip w
I'm moving forward on building my shop truck. I've got the Valiar Quiet Towing Dual Disc clutch from @dieselautopower. Started this morning getting the old flywheel and flex plate out. Come to find out the rear main seal is weeping. So, I got @Jthorto run to NAPA and pickup a rear main seal for $40. But here is what I've got...
Rear crank seal is wet. Change it now while the clutch is out...
Then slam in the flywheel...
Here is the friction disc stack.
