2001 dodge 3500
What’s up new guy here, just bought my truck a couple months ago and stumbled onto the site, lots of cool info. Look forward to sharing my truck and learning from everyone.
Like the title says it’s an 01 dodge 3500 4x4 5 speed, it has 301k miles and was a work truck for all but a couple years of its life. Start up construction company bought it in 2005 from an old man that bought it new, they put a flatbed on it and towed equipment trailers. I bought it for what I consider a good deal considering current economic times and plan on making into the weekend truck for the family, tow my boat and looking to buy a truck camper.
The guy I bought it from took pretty good care of it considering, it’s very dirty all around and a little rusty on the underside. Has a new clutch and everything works other than a/c. Crazy thing is he claims he’s never had to do a lift pump injection pump or injectors, always put 2 stroke oil in with each tank of fuel but said the shop mechanic would just fix stuff time to time and might not have told him. All I done so far is deep clean interior, change oil flush coolant and add a bhaf.
Long winded for an intro but excited for it all, thanks
Look for the VOID sticker on the VP44 electric connector if the stick is still there and not torn then yes its the OEM pump from the factory.
Grid heat has been sticking on. Hence the burnt appearance of the coating on the intake.
Lift pump is a factory location but hard to tell if its been changed or not. But still in all you need to test the fuel pressure. 14 to 20 PSI is optimal. Stock is 10 to 14 PSI. Marginal... But I seriously doubt that pump is still going strong.
Need to to the crankcase vent mod... Then do the W-T ground wire mod...
 In the first set of pics I noticed disk brakes in the rear? Mine is an '01 3500 4x4 but has rear drums. Was that an option? I would prefer disks. Just curious.
 Welcome to the forum, there is alot here to learn and gain from reading. Check out all the tech articles that apply to your your truck. Lots of stuff there.
 Nice truck! You'll love it the more you drive it.
Truck looks good!
Also, As someone else with a disc brake dually truck, keep an eye on the fluid level. They are expensive to replace. I now grease the bearings yearly. Passenger side is usually the problem child with the oiling issues.
Good to know I’ll check out the sticker and see what I can find out. I’m getting a list going of all the things I need to do to get it reliable I’ll add the grid heater to it, thanks. Yea this is my first truck with rear disks and trying to diagnose the parking brake has been interesting. Can’t tell by the pictures but, the rotors are cracked in a few spots and are badly warped. Looks to be a fun job pulling the hub off to replace them.
I could be wrong but in some research I’ve done, I thought I saw that a fix from dodge for a warranty lift pump was to install a pump in the fuel tank, curious if anyone can shed some light on that?
Edited by Concreter
In tank pumps are junk unless you can get 4th gen or 5th gen pump. Then the headache of retrofit that pump in a 2nd gen tank.
Parking brakes make sure the shoes are in good condition then set the slack on the starwheels to make the shoe lightly drag. Now set you cable slack to pull the shoes tight. Also the two rear cables are prone to rusting and binding.
The lift pumps are a concern and you should think about changing over to an electric or mechanical.  You get to make the choice. Pros and cons on both. In tank pumps suck in my opinion. Had one on mine and it did not last. About $1k for mine from Dodge 380k miles ago. If the truck is 100% stock maybe not a ticking time bomb, your guess is as good as mine.
 Mine has a fass ddrp, it's in the factory location but a better pump. Probably one of the least expensive upgrades from a factory lift pump. I plan on moving it to the frame to get it closer to the tank to make it more of a pusher pump rather than pulling fuel so far. Those pumps, factory or aftermarket, aren't meant to draw fuel so far away from the tank.
 Larger lines wouldn't hurt either. That's also in my plan. Factory lines are small. I plan on going to 3/8" line. My truck will remain mostly stock with so slight upgrades along the way but nothing to crazy. Just want reliable and long life out if her.
My DDRP is on the frame with a spin on screen ahead of it. Works very well for my stock injectors and some Quadzilla Adrenaline CANbus fueling. Now if I would just take Mike's advice to move my fuel return out of the fuel module basket, I'd really be doing well in that department. Pressure is good, but fuel temp gets hot.
Edited by LorenS
I was looking at that pump, price point is good. I didn’t think about mounting on the frame rail that would be nice. Just need to get some time from work to work on it before summer gets full swing so I can use it
