The DAP injectors will help but the big tires are still putting a big load on the engine; So Yes they will help but no they will not solve all of your problem. The RV's would help but you will loose some power. How much I dont know. I run RV's in mine on an Edge comp and they are smokey a bit until the turbo catches up.
22 minutes ago, Krlspokane12 said:
I have not received the nozzles yet. I was thinking about going with 320 and seeing what happens.
10 minutes ago, Threadzy said:
Everyone I’ve seen run that pressure  like it. I know I do.
Yup. Still good here with the 320 bar. Very clean burning very little smoke.
