Synthetic 2 stroke oil as a fuel additive?
Yes, I have been getting gallon jugs from Amazon.  They dropped it from my autoship orders.  Then I became concerned when I tried all the Crosby auto parts and they didn't have any.
I didn't state my actual concern- that it might be phased out altogether.
Thanks for the web address, I'll order from them.  Probably cheaper.
i was in my local  Walmart store today and the 2 stroke was $13.88/gal.  It's hit or miss when they have it. You can check your local store there in Crosby.   A Walmart with an auto service center in it has a better selection and stocking than one that doesn't.
30 minutes ago, IBMobile said:
That's all I've run for over 10 years.  I'm going to Walmart today to buy some before the price goes up.
we pay for the lubricity taken out and then go Walmart to put back in :duh:
  • Sad 1
This is what I use, if you can’t find the super tech, All the Wally worlds usually have this in the sporting goods/marine dept.  just about 17.O0 and some change per gallon here. I have a merc outboard that uses it so it just makes since to share a little with the truck.  As long as it’s TC-W ( two cycle -water cooled )
Thanks for your response.
That is the oil I started with.  I didn't notice it was a synthetic blend.  I had seen posts saying synthetic should be avoided, so I switched.  I'm still not clear about what the downside of using synthetic is.  I tried again to find posts specific to that, but apparently I have no forum search skills.
I had been ordering from the Evil Empire of Amazon, but thanks to forum replies, I learned that Walmart is a go-to place for 2 cycle oil.  Hooda thought it....hard to drive more than 10 miles without seeing a Walmart in the Houston area.
Thanks again for all the replies to this question.
