Another loaded 2nd gen
So I want to get rid of factory speakers, but this one has the premium audio. So by chance does anyone know if I try to get another set of new 2.0ohm for the (non oem) speaker will it work? Or do I need to gut the doors & rewire?
Next it has the heated + power mirrors
But there little, anyone know if a plug and play mirrors works ?
[Ive ordered mirrors before offline and none of the included studs have ever worked :P]
Edited by ICU_24VNUT
I redid mine keeping the factory radio and wiring, replacing the front speakers with 6X9s and 5.25" rear speakers, cut the wires to the A-post tweeters and added a Infinity Primus 6004a Compact 4-Channel car Amplifier — 60 watts RMS x 4.  I did have to add connectors and wires for the amp.  @Red Ramblerdid something similar but i think he change his radio head.   Picture of the booster under the drivers seatIMG_7442.JPG.5cc43ecf61f4287de9cab9a85d763e40.JPG
 I bought some from Amazon that were plug and play. The studs were a bit short, had to compress the foam gasket to get the nut started but once tight they were fine. Been on there for 2 years now. Mine are also heated/power.
I have the Infinity system with different speakers.  The PO of my truck had swapped in some Kenwood speakers and I could see the amps are still in the doors when I swapped in some new Pioneer speakers.  I don't know if they are working but they are there.
I also had the power heated hippo ear mirrors, I ordered a set of the 4th gen style tow mirrors from 1Aauto and they plugged right in.  I also sprung for the power folding with marker light as well and those two features you do have to wire in.
Alright so I've checked out LMC truck and a bunch of places and I can't seem to find a new woodgrain bezel by chance do y'all have any leads?
All I see LMC is the non infinity style dash & bezel.
Does the non infinity style just bolt right to it?
