Parking brake cable help
- Replies 13
- Views 6.2k
Doubletrouble 4 posts
Mopar1973Man 2 posts
IBMobile 2 posts
Max Tune 2 posts
Popular Days
With a production date of 2/00 it most likely is a 2000 model year but for confirmation check the VIN with the Dodge parts department. 2000 Dodge Ram 3500 4X4 left parking brake cable part num
2001.5 and older have drum brakes; 2001.5 and newer have disk brake pads with separate parking shoes. If you go to Rockauto you'll see both rear drum and rear disk brake parts listed for the 2001 Ra
I was thinking someone swapped cabs at some point, but that makes as much sense as a 2001 built in 2-00. The vin confirms it's an 01. I dunno. It was the new millennium, maybe the computers did it....
I recently had the parking brake hang up a little while leaving for work in the morning. I know the cable from the left rear wheel is in bad shape, outer casing is bunched up and looks to be the culprit. I would like to just replace both cables going to the rear wheels. They aren't very expensive on RA but there are so many I'm not entirely sure which ones to order. Am I going to have to measure the cables since there seems to be different lengths? There also seems to be a cut off, parts must have changed after 7/00. Mine was built 2/00 so I at least figured that part out.
Truck should be in the sig but just in case it's a 2001 (man. Date of 2/00 ) ram 3500 quad cab long bed. I don't know the wheel base (some cables show WB measurments).
Just don't want to order the wrong parts. Thanks for any help.
