- Replies 18
- Views 2.4k
Mopar1973Man 6 posts
Sycostang67 3 posts
wil440 2 posts
Great work! 2 posts
Here are some videos that will help. https://www.youtube.com/results?search_query=2001+dodge+ram+rear+door+stuck+ When I removed the rear door panels the cable for the left side broke
I was able to pry the panel open enough to see the lower rod had come off the latch. I got my hand in there and pulled on it and got the door open. The rod and clip both appear to be in good shape.
I've got plenty of clips Mike, it's the plastic on the panels that holds the clips that are breaking off. Each rear panel has 3 metal clips along with the plastic one. I only have 2 metal clip still
Here's another testament as to why I hate Dorman parts. I recently replaced both Interior door latch cables in my rear doors as they both broke when I removed the panels to replace my speakers. One of them is just barely too long, you can pull the handle and hears things move but the door won't unlatch. The outside handle still works though. The other door worked for a couple weeks then stopped opening entirely. How can I get the door open to take it apart again?
