[ATTACH=CONFIG]2259[/ATTACH] http://www.vulcanperformance.com/Push-Lock-Fuel-Pressure-Tee-1-2-p/plt8.htm Ok cool thank, this is the one that I am running about 6 inches or so from the VP44. But since we are on the subject what is the size of that needle valve and how far from the sender should it be installed?
Mine is a 1/8" NPT need valve installed in that exact fitting above... But there is a problem electric sender don't work unless you give then a ground. That the problem I got currently with my exist low pressure switch that was I suggest the fitting above. Now since the Water Hammer source is at the VP44 it highly suggested to mount your fuel pressure gauge as far from the source of the water hammer. Less damage that way. But remember the fuel pressure sender must be after the filter... So if your like me you have a stock fuel filter housing that typically will have a air bubble on top which acts as a shock absorber so if you tap the line just after the filter housing it will aid in suspressing the water hammer effect.
so your needle valve is installed in this fitting??? and your fuel sender is back at the pump???
Not sure if I follow what you're asking but you install the needle valve into the fitting and the sender onto the needle valve. Or run a grease gun hose from the needle valve and put your sender on the end of that to further dampen the water hammer.
wow ok i think i have this pictured in my head but just to clarify i would install the needle valve into the fitting and on the other side of the needle valve i would install my fuel sender??? if this is not correct does anyone have a pic of there setup???:shrug:
I think there is a pic floating around but maybe you can understand it if you work it out mentally. We know the fuel pressure hammer is what we don't want. We know the needle valve will stop it. So you would have your line running from the fuel system (which is hammering from the lift pump), then you would eliminate the hammer with the needle valve, then you would put the fuel sender on after the needle valve since it MUST NOT SEE THE HAMMER, so it goes AFTER the needle valve has eliminated it. It eliminates it by reducing the flow to the point that the bursts of pressure (the hammer) can not flow through the needle valve because the flow is almost next to nothing, so you get these positive spikes of pressure followed by a void, so you get a little pressure from the pressure spike and a void of pressure in between the pumping actions of the lift pump which gives you a fuel pressure that is basically the average of the void and the spike, because that is basically what the fuel system also sees. Now that you understand what you are trying to eliminate with the hammering effect and how everything works, you probably understand how to do it. If not, someone will have a pic or I will dig one up.
Here is a older setup...
Posted ImagePosted Image
Now what does a single water hamer pulse look like???
More about water hammer...
http://en.wikipedia.org/wiki/Water_hammer
thats what i had pictured in my head. thanks ISX. i guess somewhere in the midst of this thread i got a little turned around:shrug: but all is good now:lol:
Mike thank you for the pic, now i just have to find one a place in little southeast kansas where i can get one of those since we dont have a NAPA hear!!!:doh:
Water hammer is like jumping on your bathroom scale a million times.. You can average out the bouncing and might get your weight but it will break the scale in no time. This doesn't matter if it is a mechanical or electric sender, they both cannot take the hammering.
thats an excellent example:smart:
It's a Weatherhead Part (WH6820) you should be able to get it through any part store selling hydraulic hoses and such...
But here is the part page from Napa for you...
[ATTACH=CONFIG]2270[/ATTACH]
You are awesome man!!!:thumb1:
do you happen to have a pic of a snubber install?
Just replace the needle valve with...
As you can see a needle valve is adjustable and can be shut off where a fuel pressure snubber is a fixed offrice and never be adjusted nor shut off...
At rate the snubber or needle valve should always be installed at the source... Not at the gauge...
so i install the snubber into my existing fuel pressure tee and then the fuel sender/sensor into the snubber correct??? do you happen to have a part number for the above pic, or would i just find it at jegs, summit, etc???
http://www.summitracing.com/parts/ATM-3279/
found it not too bad of a price only 18 bucks!!!
