- Replies 12
- Views 7.8k
Mopar1973Man 2 posts
ISX 2 posts
hawkeye213 2 posts
LiveOak 1 post
Alright been messing with this for a couple of weeks. Started when it first got cold. Noticed my heat was not as warm as usual. I checked my radiator and it was about half gallon low. After I filled it up I drove it and the heat seemed to be better. When I got home I noticed some antifreeze on the ground. Looked up there and found it dripping from the drain plug. Replaced the plug which I might add is a stupid design and pretty much worthless to actually drain your radiator. Why cant it be a pitcock drain. NOOOO it has to be some nasa frickin design with an O ring that doesn't actually work after you remove it the first time. :banghead: Sorry !! Anyway it wasn't the plug anyway but a leak in the radiator up a little higher behind the shroud. Ok now this is where I get lost. This is a closed system and it will build up pressure. Why is it just dripping ? Why isn't it spewing out making a mess ? Ok so I get a new radiator and install it. Replace the t-stat got it at O'reilly's and flush the engine and then disconnect the heater hoses and pour some clr in the heater hoses and let it sit in the heater core for about and 1 1/2 hours and then flush the heater core and reconnect the heater hose. Then fill the truck up with water and then I let her run a bit cause I want to make sure I am getting flow thru my heater core so I pull the hose off on the block side of the heater core and it is pumping good then I pull off the hose on the other side of the heater core and it comes shooting out. Then I drain it again and put the truck on slight upward hill and refilled with antifreeze. Also replaced the resistor on the blower. It went out in the middle of this. Also checked the door where you switch from AC to heat it works fine. Also checked the temp selector thingy underneath there it corresonds with adjusting the temp control. It spins around and stops.Take her for a spin the truck heats up to 190 heater seems warmer ? This truck has always heated up to 190 and would move a neeedles width either way while driving. The heater has always been hot and usually if I have plugged it in after a ten minute warm up it was very toasty. Ok now that I have replaced everything the truck is very slow to reach temp at idle. While driving @ 60mph my truck will reach 190 or just a hair more but when I slow down for a stop light the temp drops down to 160 or so and then as I accelerate the temp will slowly work back up to 190. My heat is warm at best but by no means is it hot. I just left work idiled in the parking lot talking to my friend for about 20 minutes and then drove home from work 25 miles mostly 60mph. I get home and pop the hood nothing is really hot at all. The radiator is not hot or even really warm. The upper hose has some pressure on it but it is not hard to squeeze. It's warm but not real hot. The heater hoses are a little warmer. So I touch the cap and it's not even warm so take the cap off and there is just no pressure at all I look into the radiator it is still full and there is no flow in the radiator at all. I feel stupid that I can't figure this out. The heater prob could be the core. But when I pulled the heater hoses I had good flow going in and out and the water was hot. (ouch dumbass). So I am thinking it is not the core. Why is there no noticable pressure at the cap ? Why is there no real pressure in the hoses ? If it is not pressuring up you would think you had a leak ? But I don't. Why is the temp of the water seemingly not very hot ? T-stat staying open ? Then I would think I would see the antifreeze flowing thru the radiator ? But I don't. Water pump not working ? Then I would think the truck would over heat or at least get hot ? It doesn't. For some reason the cooling system is not getting hot enough. It is not creating any pressure either. It is not cold enough here to require blocking the radiator. Never had a prob before. I am sure it is a simple fix but I am just at a loss as to what ? Why does it get to 190 and then drop back so far ? Why will it not hold the heat. Before it just stayed at 190 within a needles width either way. Sorry for the long post. Any help would be appreciated. Thanks Rob
